1951 F1 U Joint Question
Old 09-17-2011, 08:33 PM
1951flatheaddave's Avatar
1951flatheaddave
1951flatheaddave is offline
Hello, planning on a 9inch swap and was wondering if the stock U Joint in the stock driveshaft will fit or if there is a specialty U Joint that I have to buy.
Thanks in advance!
Old 09-17-2011, 08:39 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,451 Likes on 1,398 Posts
It's going to depend on the yoke you have on your 9" pinion. But also know the 9" axle is larger than the original Dana, and you will very likely need to shorten your drive shaft by about an inch/inch and a half. You can get a new, matching u-joint when you have the shaft shortened. You will need to instal the new axle to get the exact measurement needed. This is not a place for guesswork.
Old 09-17-2011, 08:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Usually you use a hydrid U-joint that is commonly available, that has the stock cups on one pair of the cross, and ones to match the 9" on the other two. There is a stock Spicer number for the joints but I don't have it.
Old 09-17-2011, 09:30 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by ALBUQ F-1
Usually you use a hydrid U-joint that is commonly available, that has the stock cups (1310's) on one pair of the cross, and ones to match the 9" (1330's) on the other two.
Ask, and ye shall receive.
C5TZ-4635-F .. U-Joint-2 cups are 1310's, 2 cups are 1330's / Spicer number: 210392-X
Old 09-17-2011, 09:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You da man!
Old 09-17-2011, 10:18 PM
NumberDummy
This may be a commonly stocked U-joint, but you'd prolly be amazed on how many times I've typed this same info (over 100 times).
Peeps go to chain autoparts stores to get one or more (don't take the old one along...if they have it). So, they describe it.
The dumb counter clucks look at them as if they just landed from outer space, because they haven't a clue such a U-joint exists.
Old 09-18-2011, 06:37 AM
1951flatheaddave
You guys are the best!
Old 09-18-2011, 08:56 AM
mtflat's Avatar
mtflat
mtflat is offline
As Wayne said, install it to see what you need exactly.
The 9" I used from a 65 truck took the same ujoint as the original. No hybrid was needed.
Also the 9" carrier was shorter than the Dana 41 so I had to find a slip yoke that made the driveshaft 1.5" LONGER.
Old 09-18-2011, 09:06 AM
NumberDummy
9" rear axle u-joints. It all depends on the applications.
F100/F150's w/a 2 piece driveshaft use 3 of the hybrids (1310/1330), but if not a 2 piece drive shaft, all 4 cups are 'usually' the same (1310).
The Dana 44 also uses 1310 size u-joints and these are the same u-joints used in myriad 1957/79 Passenger Cars with 8" (1962/80) & 9" (1957/80) rear axles, 1957 and later F100/150's, Bronco's and Econolines.
Some of these 1310 u-joints are specific to front or rear, some are not...because it depends on the applications.
A member here (Kevin something or other) with a 1951 F6 needed u-joints, the parts catalog he was using had the old ancient basic number of 7039. No one had any because Ford changed the number to 4635 in 1956.
The 'new' part number was B6TZ-4635-A, that was replaced in 1963 with C3AZ-4635-J same-o same-o as 1960/70's Passenger Cars.
Old 09-18-2011, 11:27 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Yep, the stock driveshaft will be too short...
FLgargoyle
09-15-2018 09:04 PM
psychlopath
05-11-2015 09:02 PM
TinMan289
08-27-2013 07:58 AM
goodB0Y
Offroad & 4x4
05-13-2008 09:16 AM
Quick Reply: 1951 F1 U Joint Question
