You CAN swap them, and the truck should drive, however I'm not sure if OD would work properly. Might be able to wire up a toggle switch to make the TCC/OD work.
Might wanna check on crossmember differences and lengths. So you can make sure your driveshafts are gonna work.
Sounds like you are swapping an AOD trans for an E4OD. The problem is that the E4OD is computer controlled so you would need to swap in the trans wiring harness and a computer to control it.
I think in the end it'd be easier to just fix your trucks transmission or find an older C4-C6 and convert to that if you want a different transmission without spending alot.
Back to thinking this through. So the harness goes into the fuse box? If so I can swap the entire harness and colum correct? Would I also need to swap dash cluster?
