Starter Removal !?!?!?!?!
Old 08-15-2011, 02:07 PM
1979F-150Man's Avatar
1979F-150Man
1979F-150Man is offline
1990 F350 460 4X4. Removed bottom bolt. Around 10-11 o'clock there should be another bolt, correct? I see non. The starter moves a little but is still very firm. There is nothing else holding the starter in besides the 2 bolts correct?
Old 08-15-2011, 03:05 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
There should only be two bolts if I remember.... One on the bottom and one directly across (on top) from the bottom one..
If you have both bolts out, most likely it is hanging on the thin aluminum plate between the engine and trans, it may have a burr where someone has tried to put the wrong starter on it or just messed up an install... It is a close fit, it has to be as this is what aligns the starter to the flywheel..
Old 08-15-2011, 07:42 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
The bottom one goes in from the front, the top one goes in from the rear.
Old 08-15-2011, 08:03 PM
White 97 xlt
RIGHT!!!! I forgot about that!! Thanks
Getting old is H***
Old 08-15-2011, 11:44 PM
1979F-150Man
Right after I posted this I went out and realized the top bolt came from the other side. I had a Duh moment. Starter cam out and the new NAPA one went right in. Thanks for the replies.
Old 09-11-2011, 08:13 PM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
Thanks! Couldn't figure it out, did a search and found this, perfect!
Old 09-11-2011, 09:11 PM
IowanStraight6's Avatar
IowanStraight6
IowanStraight6 is offline
Napa starter? O well different strokes for different folks
mojoman
32
12-02-2008 08:10 AM
e-tek
1947 and Older Ford Trucks
06-07-2008 10:51 AM
opensourceguy
20
06-18-2007 01:23 PM
Boyd1971
10-17-2005 09:01 PM
jm21760
Bronco II
07-28-2004 12:36 AM
Quick Reply: Starter Removal !?!?!?!?!
