new starter sounds like crap , help!
Old Oct 14, 2005 | 07:34 PM
Boyd1971's Avatar
Boyd1971
I installed a new rebuilt starter on my 360 ...it sounded like a old Dodge starter winding down after it would start.Now after a week it sounds like it doesn't fully engage about 50% of the time. It sounds like the teeth are grinding against the teeth on the flexplate. When I put the starter, the instructions said to use new grade 8 3/8-16 bolts. The bolt holes in the starter are big enough to accept 3/8 bolts . The problem is my truck came out with 5/16-18 starter bolts so, I have quite a bit of clearence in the bolt holes. The bolts do not serve as any alignment feature . Is this normal for the starter to free float and can be tightened down anywhere?
Old Oct 14, 2005 | 08:15 PM
Bear 45/70's Avatar
Bear 45/70
Sounds like you got a starter with the wrong tooth count on the bendix.
Old Oct 17, 2005 | 11:14 AM
bertha66's Avatar
bertha66
Take it back and have them check to make sure they are giving you the right starter.
Old Oct 17, 2005 | 05:00 PM
RustyTrustyF150's Avatar
RustyTrustyF150
return it and tell them you want one that works right
Old Oct 17, 2005 | 09:01 PM
Boyd1971's Avatar
Boyd1971
Well, problem solved. When I removed the starter so I could return it , I noticed it had a rattle in it that it's not suppose to have. The pin that the bendix pivots on had broke loose and fell out of place. So the engagement with the flexplate was *****-nilly . Sometimes fully engaged and starting ok , sometimes partially engaged and grinding . New starter solved the problem. Thanks.
rkik
31
Sep 3, 2017 10:11 PM
Ed the outdoorman
Aug 27, 2014 09:46 AM
Tecman
Oct 6, 2009 08:22 PM
heybrent
1978 - 1996 Big Bronco
Sep 25, 2001 10:56 AM
heybrent
Sep 6, 2001 07:55 PM
