'99-'04 SuperDuty U-bolts/blocks, etc....
Category: Steering & Suspension
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): NSX
Item Condition: CA
Engine: Part suitable for gas truck, Part suitable for diesel truck
ICON (Donahoe Racing) 15" U-bolt kit, PN 37003, New in box.
ICON 1" Billet Aluminum lift blocks, PN 191200, New in box.
Fabtech 12.5" U-bolt kit, PN FTS351UBK, New in box.
Used Factory Ford lift blocks, stamped 3C745598AB, 2 3/8". I have two CCSB trucks, one a 7.3, one a 6.0, with these blocks, stacked with the above mentioned aluminum blocks, a 5" rear, and 8" front spring set, and the trucks sit perfectly level. (These are not the 1 7/8" blocks).
Used Factory Ford blocks, stamped 4x4 YC35-5A896-A, these are the angled blocks sometimes used to correct pinion angle without using shims, particularly on SB trucks without a custom CV driveshaft. 2 3/16" at front of block, 2 7/16" at rear.
Factory Ford 13" U-bolt set, off an '04 at 900 miles. These are the ones off of trucks with factory overloads. I have them on both of my above mentioned trucks, with the spring/block combination listed.
Factory Ford front U-bolt set, off of the same '04, these are the ones that are bent slightly 'round' at the U, as opposed to the early 'square' bent ones.
Also have the front spring hangers (front of front leaf) and the 'bash bar' that separates them, off of my '02 truck at 40k, no damage.
Make me an offer if you could use any of this.
Tim (951) 323-7271
Sorry Tim, UPS and FedEx are around $22-$23 to go California to New York for this box, as it weighs over 12 lbs. For $17 I will use them on something. Thanks for the offer though.
If I don't get about $40 plus the shipping for them I think I will keep them.
You may be able to get them out there for about that price if you get them wholesale.
List is about $90 from ICON, so you may be able to get them for $65 or so.
I'm interested in the front spring hangers and blocker beam. Could you send me some pictures of them so I can see their condition? Email is my forum username @gmail.com
Thanks!
Thanks!
OneSickTruck
11-16-2014 10:36 AM
