E4OD transmission fart
So, I am coming back from lunch and my transmission won't shift out of 2nd or third. I turn off O/D and it felt like the TC locked but no O/D. 2800+ RPM at 45 MPH. I think, well maybe gear selector is not engaging drive. I stop at a light, put it in park and back into drive, continue driving but no change. Still won't shift. I figure it must be some computer glitch, so I stop at the next light and put the truck in park, shut it all the way off, start it and continue driving. This time I get all my gears and O/D works.
No, the O/D light did not flash.
Any ideas what this means? Problem with operator or transmission? I'll report back when/if I get home later this afternoon. I have never had this happen in the truck before.
1991 F250 7.3 IDI all stock.
OK. The two messages the guy at O'Reilly's saw was a MAP sensor pressure fault and the TPS. The TPS may be because my throttle cable is messed up. I'll have to figure out what a MAP sensor does.
Edit: At the time, I thought a MAP sensor if for a computerized gasser. It is starting to look that way to me.
Eaton I can tell you from your description that it was your TPS that was causing it. I can tell you this cause my 94 just did the same thing. Check the voltage on your TPS with a meter with the key on and engine off. Bottom wire should have 5 volts, top wire should have no volts, center wire should reat somewhere between 1 and 1.2 volts with the throttle at idle and should go up to between 4 and 4.5 volts when you push the throttle level to wide open. I couldn't get my TPS to adjust to with in range so I put a new one on it day before yesterday and problem solved and no more code 23 on the reader!
Yeah, I adjusted it when I put the old pump on. It is at 1.08-4.28 if I recall correctly.
Banks_93_IDI
15
02-27-2018 03:23 PM
TheGuyOverThere
06-09-2014 08:30 PM
