stuck sliders
Old 08-10-2011, 12:26 PM
Jmudweiser's Avatar
Jmudweiser
Jmudweiser is offline
stuck sliders
will heating up the caliper damage it. my slider pins are froze up.
Old 08-10-2011, 12:30 PM
clem1226's Avatar
clem1226
clem1226 is offline
Correct me if I am wrong but doesn't the slider bolt to the caliper and slider inself fit inside the caliper bracket?
I had 2 stuck pins last time I did brakes and fought with removing them from the brackets for 2+hours, then I got on line and found you could buy replacement brackets from O'reileys for $10 a piece. That's a heck of a lot cheaper than 2 hours of my time.
link to O'reileys brake bracket ....ok so they want $16 for the back and $20 for the front but it is still cheap compared to the pain of trying to remove a seriously stuck pin.
Old 08-10-2011, 01:20 PM
Jmudweiser's Avatar
Jmudweiser
I stand corrected! Lol its stuck in the bracket. Thanks for the link! I just assumed the bracket would b a dealer item! Thanks!
Old 08-10-2011, 02:26 PM
arto_wa's Avatar
arto_wa
arto_wa is offline
You can also find the brackets from eBay for under $23 including shipping!
1999 f350 brake caliper | eBay
Last night I had to heat the driver side bracket a little, in order to get the upper pin out.
I doubt little heating will do harm, as long as you don't overdo it!
Old 08-10-2011, 02:33 PM
arto_wa's Avatar
arto_wa
arto_wa is offline
It's best to replace the pins, since they are the parts rusting most - not the cast iron brackets.
Set of new pins installed with synthetic disc brake part grease and new seal boots should make them work for long time.
Old 08-10-2011, 04:54 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
If u take the caliper bracket off, pinch the caliper pin in a vise, and give it a good whack downward with a hammer, it will usually pop out. Clean it up, replace the pins and lube everything nicely and u should be gtg
Old 08-10-2011, 06:44 PM
badhabit1's Avatar
badhabit1
badhabit1 is offline
Heated mine with acetylene torch, came right out. Used a bristle cleaner designed for a 12 gauge shotgun and cleaned out the holes, used some 500 grit sandpaper on the pins. Like 1 dollar spent. Good as new.
Old 08-10-2011, 08:51 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
I just changed my front caliper because it stuck about 5 miles from home my brakes were smoking when I pulled in the drive way. I let it cool for about 45 mins took it off and when I took it to the parts store it was still warm about 2 hours later. Not a thing wrong with the pads or rotor believe it or not
Old 08-10-2011, 09:31 PM
Jmudweiser's Avatar
Jmudweiser
The caliper or sliders locked up?
Old 08-11-2011, 09:08 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
caliper locked up
Old 08-11-2011, 09:09 AM
damicofuel's Avatar
damicofuel
damicofuel is offline
Advanced Auto has caliper,bracket,slides and pins for 62 bucks!
Old 08-11-2011, 09:27 AM
damons's Avatar
damons
damons is offline
My boots are missing, am I better off replacing pins too? They seem to be ok now that I cleaned out the bracket and relubed them, I just don't have the rubber boots to hold the lube.
URDADDY
6.4L Power Stroke Diesel
01-07-2014 11:32 PM
KRUSTY51
07-28-2010 12:50 AM
joeycyph56
1999 to 2016 Super Duty
08-02-2009 11:37 PM
5.4L to Freedom
13
01-04-2009 06:19 PM
JEV
13
07-03-2008 09:06 AM
Quick Reply: stuck sliders
