Power Steering Pump Whining
sure. mine whines at idle all the way to 70mph.
no cavitation though and i've never had a burp in the steering so no issue IMO.
but if your getting cavitation or unresponsive steering then you might want to change it, or look into the e-van swap.
course you may have a bad bearing. which would be another reason to change out our pump
give this a read https://www.ford-trucks.com/forums/1...placement.html
also Saginaw Power Steering Pump Swap on 302/351W F-Series/Bronco - Ford Truck Fanatics
