Power steering pump
Old Oct 3, 2012 | 11:15 AM
kegomatix's Avatar
kegomatix
Power steering pump
Hello everyone just had a quick question. I changed out my power steering pump on my 93 5.8 and I was just wondering, what is a normal amount of noise coming from these things? I know these trucks are infamous for power steering pump whine but I don't know how much, if any is a good thing.
The steering is now smooth as can be and the only time it whines is at a stop and turning the steering wheel. I understand that is when it is under the greatest load so I'm expecting some noise is normal? Overall it is %100 better than the old pump, though. Thinking maybe I didn't bleed the system well enough or maybe it has a leak somewhere that I'm not seeing.
Old Oct 3, 2012 | 11:29 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Does it only make noise when cold, or all the time?
I assume the fluid level is correct, if it is and you have been driving it around, I dont think there is any air to bleed out, as it would have bled while driving.
What fluid did you use in the new pump? I have read on this forum that using a premium ATF like Amsoil multi-vehicle will quiet the pump drastically. I have been siphoning the reservoir dry and topping off with amsiol periodically to change over the fluid. It was noisy at first but has stopped once I started using the syn fluid.
Old Oct 3, 2012 | 11:35 AM
kegomatix's Avatar
kegomatix
It's a continuous noise through all operating temperatures. Fluid level is good and I have been driving it for a couple days now. I used a standard power steering fluid in it, maybe I will give the ATF a shot, thanks for the tip.
Old Oct 4, 2012 | 06:52 PM
minnesotafisherman's Avatar
minnesotafisherman
Common problem with Fords. I think it's because the internal gears are plastic or something? Can't remember the reason why.
A lot of guys on here swap to the Saginaw power steering pump, eliminates the noise issue entirely, and provides more turning power.
BigRed26
Sep 8, 2015 03:46 PM
Bigches
1983 - 2012 Ranger & B-Series
17
Aug 30, 2009 10:35 PM
rickdb1
19
Dec 19, 2006 02:18 PM
DAAJR
Sep 27, 2004 03:08 PM
F150Driver
1997 - 2003 F150
Nov 14, 2002 10:41 AM
