'96 5.8l, No power after distributor swap
Old 11-01-2015, 04:31 PM
phizkig's Avatar
phizkig
phizkig is offline
My '96 F250 recently just stopped running. I parked it after work and it wouldn't start the next morning. The problem was fixed by replacing the distributor.
Now, the engine starts and idles fine but is extremely slow to increase in RPM when the throttle is opened(meaning extremely slow throttle response), and when driving it has absolutely no power.
I have fuel pressure at the schrader valve. OBD1 test produces no codes other than a 512, and yes the battery was disconnected.
I'm not certain exactly where the timing is set, however the new distributor is in the same location as the old, and idle speed is the same. Advancing or retiring the timing does not help the problem.
I don't know which direction to go with this and need some help.
Many thanks in advance!!
Old 11-01-2015, 04:49 PM
dixie460's Avatar
dixie460
dixie460 is offline
Did you put the SPOUT jumper back in after you set the timing?
Do you not have a timing light? If not you can get it close with a vacuum gauge, do you have one of those? You can rent, for a fully-refundable deposit, a lot of tools from AutoZone and I think Advance too. Call and see if they'll rent you a timing light.
Old 11-02-2015, 03:50 PM
phizkig's Avatar
phizkig
phizkig is offline
I have all the necessary tools, just haven't used them yet. My gut says this lack of power is component related rather than timing, but I've been wrong before. I'm just looking for another angle to approach this problem.
Old 11-02-2015, 04:10 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Dixie is suggesting the timing is locked because the TFI is not getting a signal back from the computer.
Old 11-02-2015, 04:56 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
If the timing is off, (and most likely is, if you haven't set it since replacing the distributor) you can approach it from as many angles as you want, but the first angle should be "check the darn timing!!!"
Old 11-02-2015, 09:47 PM
phizkig's Avatar
phizkig
phizkig is offline
LOL!!! So I guess it's official, I need to get off my fat rear axle and break out the vacuum gauge and timing light...
Thanks for nudging me in the right direction!!
Quinnbristow
1978 - 1996 Big Bronco
05-29-2013 12:42 AM
92fordman
09-19-2007 02:57 PM
ColonyPark
4 Cylinder Engines
24
08-01-2006 08:55 PM
jaye
07-10-2006 10:34 AM
GSchretter
10-06-2004 02:06 PM
Quick Reply: '96 5.8l, No power after distributor swap
