Excursion A/C not cold
06-23-2011, 06:58 PM
on
My '03 Excursion v10 is not as cold as it should be.
Idling on a hot day Im only getting 65F out of the vents. The X is black, and Im in Houston..
so please help a brutha out
-Compressor clutch engages correctly and compressor continues to run as long as needed
-R134 level/pressure is good
-Condenser cleaned/degreased
-Fan Checked and working well/ giving good airflow
06-23-2011, 07:24 PM
Black on black on black ?
06-23-2011, 07:34 PM
Look at the gray vacuum line that runs from your right side just over valve cover to rear of ac fan on outside fire wall.
Mine had popped off... I put back in and all was good.
06-23-2011, 07:51 PM
on
Quote:
Originally Posted by
EXv10
Black Limited (All black on outside) and tan interior
06-23-2011, 07:53 PM
on
LivingLarge
Yessir.. thats fine. I also tested the operation/vacuum of that valve too.
06-23-2011, 07:54 PM
Also, check your compressor clutch gap. If it's too wide, the compressor is not engaging.
06-23-2011, 08:07 PM
on
jh818
Yessir, done.
The gap is good and the compressor engages and stays engaged when necessary
06-23-2011, 09:10 PM
How about your evaporator fins? Are they cleaned out?
06-23-2011, 09:31 PM
on
jh818
Nope, Ill check that too. I guess the front and rear. where are they located?
06-23-2011, 09:33 PM
on
Im gonna check the orifice tube also, do I need to evacuate the r134 for that?
06-24-2011, 09:09 AM
on
Buford_T_Justice
Mustve had a brain fart
cuz I know where they are. BUT do i have to disconnect the evap. and take it out in order to clean it?
OneTon4Fun
07-31-2017 10:07 AM
ZacCobb
06-27-2017 01:21 PM
Kenneth Seabolt
05-08-2017 11:28 PM
02expy
06-29-2016 03:52 PM
05blueEx
07-19-2011 03:41 AM
2002 ,
2005 ,
ac ,
air ,
cold ,
conditioner ,
cooling ,
excursion ,
ford ,
forums ,
front ,
levels ,
proper ,
rear ,
v10 ,
working
