Found an oil leak!
Found an oil leak!
I did not see this when I was looking under the truck a few days ago, but last night when cutting my old exhaust off, I found a drop of oil on the end tip of my oil filter. Above the filter looks pretty wet too. I looked from the top and the VC looks a little cruddy. I plan on spraying it off a little tonight with some simple green and wiping off the oil filter and tightening it a bit more. My question is are there any big problem areas there for leaks? I will post a pic in a few.. doesn't show much but gives an idea of what I'm talking about.
Brian
this shows the moisture above oil filter almost looks like drops on bottom of ex man. Could it be spraying from oil filter?
. Sorry my phone flash was acting weird.
Brian
That's what I've started doing in other areas like the IC area I had some caken on grime. Oh, I also know I have a rubber line to metal line going to the IC area that is leaking. It is towards the front of the engine, with a metal line going to the Radiator/IC area.I think this is too far forward for this leak though.
Thanks,
Brian
Thanks,
Brian
Waterfowler90
1999 to 2016 Super Duty
12-06-2015 06:13 PM
