Found an oil leak!
Old 08-12-2014, 09:30 AM
blackgold50's Avatar
blackgold50
blackgold50 is offline
Found an oil leak!
I did not see this when I was looking under the truck a few days ago, but last night when cutting my old exhaust off, I found a drop of oil on the end tip of my oil filter. Above the filter looks pretty wet too. I looked from the top and the VC looks a little cruddy. I plan on spraying it off a little tonight with some simple green and wiping off the oil filter and tightening it a bit more. My question is are there any big problem areas there for leaks? I will post a pic in a few.. doesn't show much but gives an idea of what I'm talking about.
Brian
this shows the moisture above oil filter almost looks like drops on bottom of ex man. Could it be spraying from oil filter?
. Sorry my phone flash was acting weird.
Old 08-12-2014, 10:07 AM
UP_There's Avatar
UP_There
UP_There is offline
I would pressure wash EVERYTHING underneath there, and start fresh. Watch it pretty closely, and your leak will reveal itself pretty quickly I'm guessing!
Old 08-12-2014, 10:27 AM
blackgold50
That's what I've started doing in other areas like the IC area I had some caken on grime. Oh, I also know I have a rubber line to metal line going to the IC area that is leaking. It is towards the front of the engine, with a metal line going to the Radiator/IC area.I think this is too far forward for this leak though.
Thanks,
Brian
Old 08-12-2014, 10:32 AM
David7.3's Avatar
David7.3
David7.3 is offline
Your on the same side as the CCV, Iv'e seen those screws loosen up and oil walks down to back side of the VC. Check that as well.
Old 08-12-2014, 11:12 AM
blackgold50
Never looked at or thought about the CCV. I will look for it today.
Brian
Old 08-12-2014, 12:47 PM
Jesser02EX's Avatar
Jesser02EX
Jesser02EX is offline
I had an issue with a loose valve cover bolt in the rear. Just didn't get tight enough. I was scared it was the heater hose connection, but it was just the loose bolt.
Old 08-12-2014, 12:51 PM
blackgold50
That sounds like a good idea too... go around checking the bolts for snugness.
Thanks,
Brian
c mobley
2015 - 2020 F150
15
01-22-2024 01:24 PM
wb6anp
2017+ Super Duty
23
04-23-2017 08:45 PM
Waterfowler90
1999 to 2016 Super Duty
12-06-2015 06:13 PM
unhcp
09-28-2011 11:57 AM
kitebuz
04-12-2011 11:18 AM
Quick Reply: Found an oil leak!
