I get oil leaking around the filter. It's almost like it sprays a little as it gets on the plastic molding right behind the top of the filter. It's not enough of a leak to notice between oil changes on the dipstick, but it is getting messy around the oil filter.
When I changed the oil & filter, added 14.25 qts (so as not to over-fill), confirmed the level several times on the dipstick as being ok, & wiped the molding down behind the filter. I checked it again at 1,500 miles, and there was again more oil on the molding - enough to wipe off, but not enough to drip.
I haven't cleaned it in a while now, and it has been accumulating around the top of the engine over time:
around the oil cooler possibly. unless its coming from the low pressure oil pump and the fan is spraying it but i doubt it. get a new oil filter housing because thats where the bulk of it looks to be coming from and start from there. my guess is its either cracked or the o ring under it is cracked
My best guess would be the blue turbo elbow hose has a small split in it. Sometimes very hard to see without removing it.
i agree in a way and not sure about it in another. that almost seems like to much oil for the ccv hose to put out unless the turbo has a oil leak in it and the blue hose is cracked.
I was reading about the replacing the blue hose, and will give it a try. There is about 70k miles worth of oil build-up on the engine from what ever is leaking. I will also give it a good cleaning, and see how she goes.
I am curious to see whats causing this. I would also check the blue hose to the turbo, mine was leaking and it caused a mess under my hood over time, replaced it and powerwashed my motor and its been good so far.
Yeh - it has slowly been building up over the 70k miles. I will replace the blue hose, clean it all up, and post up results. I would get signs of oil spray near the oil filter head after 1,500 miles in the past.
