EGR Block-off Help
Old 05-06-2011, 01:44 PM
kentuckyredneck's Avatar
kentuckyredneck
kentuckyredneck is offline
EGR Block-off Help
My EGR tube is broken and I had it semi-fixed using a piece of hose from my SMOG system. Well the hose got too hot and broke. I'm gonna block the ends of the EGR off for now (until I get the money to buy a new tube). What do I need to block off? I'm getting a pipe cap and pipe plug for the fitting on the intake-manifold and the bottom of the solenoid. Do I need to block-off where the solenoid hooks to the upper-intake too? Thanks.
Old 05-06-2011, 03:37 PM
subford's Avatar
subford
subford is offline
Just remove the vacuum line from the EGR valve and plug it. The valve should stay closed.
You may have to pull the upper intake to plug the EGR tube at the lower manifold.
Old 05-06-2011, 09:06 PM
kentuckyredneck
Thanks. I can get the plug in there pretty good with it together. I'm gonna try using a socket and swivel to tighten it. So blocking the port into the upper-intake was a waste of time?
Old 05-06-2011, 09:19 PM
subford's Avatar
subford
subford is offline
With no vacuum on the valve it should be closed.
Old 05-06-2011, 10:08 PM
mean green 91's Avatar
mean green 91
mean green 91 is offline
i used jb weld and just filled in the place where the stupid flexi tube broke.
wont hold forever but neither will the weak tube ford used. and it works great right now. plus the price was right
Old 05-06-2011, 10:39 PM
kentuckyredneck
Thanks subford, will it still show a CEL?
mean green, I hear ya. I thought the problem was a leaking manifold when I first heard it, so I plastered part of the manifold with the biggest hair-line crack in it with JB. I'm lookin at how to fab a better tube for next time now.
Old 05-07-2011, 05:51 AM
subford's Avatar
subford
subford is offline
Yes you will get a CEL.
OR
you can put a block off plate in between the valve and the upper intake and leave the vacuum on the valve and you should not get an EGR code.
Old 05-07-2011, 06:31 PM
kentuckyredneck
I fixed it a bit ago. Everything's together and it's running and sounding better. I put a plate (actually part of a coke can with permatex on the sides (didn't have a gasket at the house). I'll get/make a better plate soon.
Old 05-07-2011, 07:30 PM
BRay09's Avatar
BRay09
BRay09 is offline
5/8" freeze plug will fit snugly in the hole of the EGR. Thats all you need to block it off
Picton
6.4L Power Stroke Diesel
09-22-2017 10:56 AM
wedge542
04-17-2017 12:37 PM
DarkStarMedia
11-23-2016 11:03 PM
tubbstravis
1999 to 2016 Super Duty
09-25-2016 06:31 PM
wedge542
04-23-2016 08:25 PM
Quick Reply: EGR Block-off Help
