up pipe egr blockoff
Old Apr 9, 2017 | 05:15 PM
wedge542's Avatar
wedge542
i want to block off the up pipe for time being, wheres best place to get a blockoff for this not weldin type?
Old Apr 9, 2017 | 07:51 PM
KIDkiser's Avatar
KIDkiser
You can't block the up pipe off
Old Apr 9, 2017 | 08:52 PM
wedge542's Avatar
wedge542
not the uppipe,the tee that supplies exh to the egr, but i found one on ebay already,thanks.
Old Apr 9, 2017 | 11:31 PM
run6.0run's Avatar
run6.0run
Freakin junk crap!!!! IMHO,, you will be doing a disservice to the truck using that. But,, there's never enough time or money to do it right the first time,, but always enough time and money to do it again.
Old Apr 10, 2017 | 09:33 AM
wedge542's Avatar
wedge542
If you know what your doing no prob,how can it be junk its justa piece of metal,maybe low grade who knows.
Old Apr 10, 2017 | 10:05 AM
2006powerstroke90's Avatar
2006powerstroke90
I understand what you're trying to do but I don't understand how you're trying to do it.
You're looking to block the exhaust flow into the EGR cooler itself?
I'm like 99% sure you can't just plug the up-pipe and leave the original EGR cooler sitting there?
EGR BYPASS BLOCK-OFF/DELETE KIT FOR 03-07 FORD SUPERDUTY 6.0 POWERSTROKE DIESEL | eBay Is this the kit you are looking at?
Old Apr 10, 2017 | 11:14 AM
wedge542's Avatar
wedge542
yes you can,no exh going to it just water,weld the egr valve so never opens. no thats not the kit but is the piece that blocks the exh to the egr,that little plug in the pict .
Old Apr 10, 2017 | 12:52 PM
run6.0run's Avatar
run6.0run
I must not be understanding what you are doing.
But that little puck that people put on the up pipe flange results in more exhaust bellows leaking, that exhaust bellows not leaking.
Old Apr 10, 2017 | 03:09 PM
wedge542's Avatar
wedge542
I think when some installed this they was prying on the pipe to install and bending the bellows out of orig shape and later leaking,if done without the prying bellows should be ok,it would be same as adding a full delete kit with a solid egr uppipe but anything can happen if pryed on, Im going to do a full delete later while doing other stuff but id like to stop all exh from going into the egr cooler so no chance of it ruptering and causing more probs now.
Old Apr 10, 2017 | 04:56 PM
2006powerstroke90
I really don't think you understand how it's actually blocked off or how it would work. But I would definitely be interested in seeing how you get it set up
Old Apr 10, 2017 | 05:29 PM
wedge542's Avatar
wedge542
no biggy ,found the part this post was asking for.
Old Apr 10, 2017 | 06:03 PM
2006powerstroke90
You can't put that plug in to "block exhaust flow" and put the egr cooler back in its proper place. If you can hats off to you.
Old Apr 10, 2017 | 07:30 PM
wedge542's Avatar
wedge542
yes you can,thousands been done already, what plugs made for, lol,readup,not the first here.
Old Apr 10, 2017 | 07:57 PM
2006powerstroke90
I understand that. I have that exact plug in my truck
unless you're talking about freeze plugs in the cooler itself. Then yes it can be done
Old Apr 10, 2017 | 08:38 PM
wedge542's Avatar
wedge542
They have a stainless plug that beveled on one side,has a stepup on other side that goes into the egr cooler inlet,as you tighten the v clamp it pushes the plug tighter into both the uppipie tee and the coolers inlet making a tight seal both ways,was going to remove pipe,install plug,reinstall pipe,leave bottom loose do v clamp end first,then tighten bottom,trying not to pull intake,turbo right now., Thats the plan anyway,you know how plans work tho.
