Stock Lightning shorty headers?
Anybody bolted them up to a stock 5.0 Y-pipe? I'll be pulling the motor on my wife's '92 F-150 aka "Big Red", and I have the stock headers from my Lightning (went to longtubes) hanging on the wall. Wanted to throw those on in place of the old manifolds. Will the y-pipe bolt up, or will the 2.5" driver side and 2.25" passenger side collectors be too big for the flare on the pipe? What size is the stock y-pipe? 2.25"? 2"? I know the real solution is to build an appropriate, mandrel bent y-pipe, but the budget is tight, and this motor needs rebuilt.
They would bolt up. I run lightning shorties on my motor.....BUT the ball flange will be too large for stock y-pipes. I built a custom y-pipe to accomodate. You can see the pictures and the difference between the restrictive stock pipe (and flange differnce) and my custom ypipe on this thread....I posted pics.
https://www.ford-trucks.com/forums/1034582-y-pipe.html
Well, I found out last night. Working on getting the motor out of the '92, got the cat-pipe pulled off in 1 piece, just in case I need to re-use it. Set it on the floor, went and grabbed one of the lightning shorties off the wall, tried to set it on the pipe flange, the collector went right over it! As in the headpipe fits inside the hole of the collector! Definitely not going to work, LOL. The manifold outlets and headpipes appear to be 2"! So, stock is 2" dual pipes into 3" single, then down to 2-1/4" single where it comes out of the second cat. No wonder this thing is such a turd! What were they thinking? I'm going to try my damndest to get a new exhaust on this when it goes back together, I may have to run a dump instead of a tailpipe for a while, but I don't want to put this crap back on!
