Questions on a new to me '92 F150
Old 05-28-2012, 08:03 AM
Jacobs Daddy's Avatar
Jacobs Daddy
Jacobs Daddy is offline
Originally Posted by Lazy K
The E4OD will save a fortune in gas for you over a C6 but for towing, it is essential that you keep the trans fluid cool. Maybe consider fitting an extra trans cooler if towing often.
Ok. Thanks
  #32
Old 01-13-2014, 09:48 PM
Robs92's Avatar
Robs92
Robs92 is offline
Originally Posted by Robs92
OK so I picked up a 1992 F150 XLT supercab 4x4
Another update, 3 years I have owned this 92 F-150...
Radiator finally went out on me the other day, it's at a shop, decided to get the Timing chain cover leak fixed.
other than that, it's been rolling along great!
I will update a pic when I get it back.
  #33
Old 01-13-2014, 09:58 PM
adam.hilberath's Avatar
adam.hilberath
adam.hilberath is offline
Been driving f150's for the past...3 years i think, the one i got now has been back and forth cross the country 4 times. 24+ hour drives, non stop, only shut off to fill up, Most reliable vehicle i have ever owned. Love it more every day, as im sure you do too
  #34
Old 06-28-2014, 08:44 AM
Robs92's Avatar
Robs92
Robs92 is offline
my vents stopped blowing air... only the defrost was working.
went looking around for a suspect vacuum hose, and found a white tube in the engine comp. on the passenger side broken, took out the section of tube that was brittle and replaced with a scrap piece of vacuum hose... started it up and I have air again.
  #35
Old 06-28-2014, 08:47 AM
Robs92's Avatar
Robs92
Robs92 is offline
noticed water in my headlight, removed the housing, to get to it, and broke my clips off as they were a little rusty, doubt they were ever removed. So found some replacements at NAPA Part Number: NOE 6652445 - Headlight Adjusting Bar Retainer ( 2/pack )
  #36
Old 06-28-2014, 11:43 AM
Robs92's Avatar
Robs92
Robs92 is offline
Changed all the running light bulbs ( #194 ) on the roof, all working!
Headlight back in
* Next up R-134a conversion.
F350JOHN
266
02-28-2024 05:32 PM
propellerhead
15
04-25-2017 12:28 PM
86F150302
26
12-30-2016 08:25 PM
Raleigh1
1978 - 1996 Big Bronco
682
03-18-2016 01:29 PM
79F150EFI
08-27-2007 06:33 PM
Quick Reply: Questions on a new to me '92 F150
