Trans questions
Old Jun 24, 2014 | 06:40 AM
sibernut's Avatar
sibernut
Trans questions
94 F150/302 2wd. I think I remember I have an E4OD, says "METRIC" on the pan. Anyway, it's got 256 on the clock and I bought a used 2000 engine for it.(You guys gave me good advice on not swapping the EFI from it, I'd be glad to sell the whole top end). I replaced the trans w/ a Ford reman 130,000 miles ago & it's still performing well. Question is, should I get a reman while I have the engine out w/this trans, this mileage? What mods can/should be done if I do, or to this trans & keep it? Not a hot rod at all, reliable daily driver. Tks in advance, you guys know your stuff!
Old Jun 24, 2014 | 07:48 AM
DBGrif91's Avatar
DBGrif91
If the trans is still working well, I don't think you should replace it, especially if you're not looking for extra performance or anything like that. As a DD there aren't any performance expectations on the trans except to operate as normal. If it's due, flush/replace the fluid and call it good. Back to that old saying "If it ain't broke, don't fix it" kind of thing.
Old Jun 25, 2014 | 05:49 AM
sibernut's Avatar
sibernut
Trans
Tks, just thought at that age/mileage that trans might be ready to go.
Old Jun 27, 2014 | 10:41 AM
DBGrif91's Avatar
DBGrif91
I don't know what the factory life expectancy is on them, but as with any mechanical component, if you properly maintain it (in this case w/ regular fluid changes at recommended intervals) and don't beat it up, it's going to keep on keepin' on... generally speaking. There's always going to be the chance of a failure that you can't predict or expect, but that can happen with brand new cars as well as 20+ year old cars.
My 1991 E40D has 180k on it and is still going strong.
The only thing I'll caution you about the fluid change is to make sure you buy the right fluid. By 1994 they were well past using Type F in their transmissions, but I accidentally dumped a quart of it in mine once and had to do a complete flush and fill (as well as filter change) on account of that mistake. It's easy to read the label as "Ford ATF" and miss the "Type F" part, so just pay attention to that.
Old Jun 27, 2014 | 12:16 PM
sibernut's Avatar
sibernut
E4OD
Tks for the input! My trans is currently a Ford reman, calls for Mercon5. ( I put a big label under the hood.) If you were putting in a 302 w/100K on it, what would you change same time? Freeze plugs (behind flywheel!), oil pump, timing chain, or does this stuff seem pretty bulletproof? Tks for the help!
Old Jun 28, 2014 | 08:24 AM
DBGrif91's Avatar
DBGrif91
If you don't know the history of the engine (meaning the last time it's had any kind of maintenance) then a good "once over" certainly won't hurt anything. Here's what I recommend:
1) Flush the cooling system, which in turn means replacing the freeze plugs (I prefer the expandable plugs to the original type - much easier to install - and make sure to index mark the flywheel to the crankshaft before removing it - in theory it shouldn't matter but IMO it's always better to put things back together the same way they come apart)
2) Replace timing chain and sprockets (this is recommended every 50k anyway, so even if it was done when it was supposed to be, it's due again - also, since the water pump will be removed for this procedure, carefully inspect it for bearing noise and/or play - replace if suspect)
3) Exhaust studs (the ones for the Y pipe are my primary concern, but depending on what the manifold to head studs look like, I'd also replace those)
4) Oil pan gasket (you practically have to pull the engine to replace this anyway - and do this AFTER you've replaced the timing chain and sprockets and installed the timing chain cover)
5) Check the AIR injection tubing and connections at the back of the heads and repair/replace as necessary (if you're deleting it, you should be able to use plugs for the heads)
6) Then all of the "usual stuff" like spark plugs, wires, distributor cap, etc.
That's all I can think of. I hope this helps and that your project goes well!
Old Jun 28, 2014 | 09:09 AM
sibernut's Avatar
sibernut
Tks, all good suggestions. Probably have to change the pan to fit my truck anyway. Should I spring for a new oil pump, Mellings or ? I'm putting on shorty headers as part of the swap, so I'll be replacing the studs there too.
Old Jun 28, 2014 | 11:08 AM
krooser's Avatar
krooser
If it ain't broke don't fix it…
A new std. oil pump will be OK… no need for a high volume pump IMHO. A Melling or other brand name pump will work.
Old Jun 28, 2014 | 11:54 AM
DBGrif91's Avatar
DBGrif91
Agreed. Again, not saying it doesn't happen, but oil pumps tend to last the life of the engine on account of the fact that they're practically always submerged in oil and well lubricated. Granted, without regular oil changes (or allowing the oil level to get extremely low), they can sludge up and fail, but it's driven mechanically off the distributor shaft, which is driven mechanically off the cam. As long as your timing chain is in tact the oil pump will work.
But I suppose, since you're going to have the pan off anyway, it's right there and easy to get to. As krooser said - a standard pump should work just fine.
Old Jun 28, 2014 | 02:02 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you would have been ok with a quart of type F in her.people used to pour in a quart of type F in trans that called for mercon/dextron to firm up the shifts a bit.it wouldn't have hurt it any.
Old Jun 28, 2014 | 02:36 PM
krooser's Avatar
krooser
Our dirt car uses a GM metric 200 converted to a single speed forward and reverse and uses Ford Type F...
granny_rocket
May 10, 2015 04:49 PM
Backwoods351
35
Aug 30, 2014 05:13 PM
BiggDogg77
Jan 30, 2013 07:01 AM
bmuhlbach
Escape & Escape Hybrid
15
Jan 10, 2011 09:26 AM
Jc_4_07
Jul 7, 2009 01:40 AM
