How do I remove shift lever on '97 Ranger 4 cyl
Old 01-05-2011, 10:23 PM
Mudhorse's Avatar
Mudhorse
Mudhorse is offline
Hi all - I am replacing the clutch on my 1997 Ranger and I cannot get the shift lever off of the transmission. My manual (it's garbage) references a picture that doesn't exist. Can anyone help me out here? Thank you.
Old 01-05-2011, 11:54 PM
CougarXR02's Avatar
CougarXR02
CougarXR02 is offline
I had an F150 that was equipped with the M50D trans and it had a taper bolt that attached it. You took the nut off, then threaded it onto the opposite end, and tightened it. It drew the tapered bolt out. I thought it was a strange set up myself. Yours may have the same.
Old 01-07-2011, 12:08 AM
Mudhorse's Avatar
Mudhorse
Mudhorse is offline
Thanks a lot Cougar! I tapped it with a hammer, brought the nut around to the other side and threaded the stud out enough to pull her out.
Old 01-11-2011, 10:10 PM
xxshine's Avatar
xxshine
xxshine is offline
If it's not to late, consider going with a Hurst shifter. It has 40 % less throw. Make sure that the shifter has a vent hole at the base of the shifter.
Old 01-12-2011, 09:29 AM
Mudhorse's Avatar
Mudhorse
Mudhorse is offline
Thanks for the input, but this thing is so plain and stripped down that there isn't any sense in mod-ing it up. It is just my spare vehicle when the fun rig isn't running right. I'd like to replace it possibly with a 3/ ton in the next couple of years.
jmuenchow
06-01-2018 03:45 PM
youngblood1989
08-17-2016 05:13 PM
Guardianangel5699
02-21-2016 02:35 PM
jeff Heidel
1999 to 2016 Super Duty
09-01-2015 04:56 PM
Big Sky
20
02-05-2013 01:11 PM
Quick Reply: How do I remove shift lever on '97 Ranger 4 cyl
