so i'm new to both site, and in depth mechanics. what i have is an 89, e-350, 460, c-6.i just purchased the van and upon driving it home the (what it felt like was) the tranny disengaging. since I'm no mechanic i figured tranny filter and fluid change. everything is done (thanks to members here) except for refilling the tranny. My problem is that in the procees of refill iv\'ve yet to get a clear reading on the dipstick (it's all over the stick with no clear indicator of level) Sooooo being the mechanical genius that i am i have poured the old fluid back into the new bottles and we're pretty close to even steven. my concern is that what if the level was low to begin with and why can i not feel good about reading the stick
You have to let the fluid drain down the tube before it'll show the correct level. Start the engine, shift the lever through all positions and then back to park, then check the level. If it's not at the right point, add more, shift it through the gears again, and check again.
