Auto Tranny Fluid
Old Dec 30, 2011 | 10:34 PM
Blue and White's Avatar
Blue and White
Auto Tranny Fluid
I'm planning a fluid and filter change on my '78/400M/C6. I can get type F fluid in quarts. If I have it done at a lube shop, I'm pretty sure they will drop the pan, flush it and re-fill with "universal dex/merc" fluid. Should I drop the pan and change with "type F" or should I get it flushed and filled with the universal fluid?
Pro and cons?
Old Dec 30, 2011 | 11:37 PM
smokeyb97's Avatar
smokeyb97
Pro and cons?
I would use what ever you've been running in the tranny. I prefer having the system flushed, you're sure to get all the old fluid replaced with new.
Old Dec 31, 2011 | 01:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6: 1966/76: Type F / 1977 and later: MERCON
1973/79 Ford & Lincoln Mercury Passenger Car & Truck Parts Catalogs:
XT 2-QDX .. Automatic Transmission Fluid-"MERCON" 1977/79 C4 & C6.
Old Dec 31, 2011 | 09:39 PM
meborder's Avatar
meborder
Based on what ND just posted, it looks like mercon should be the right choice.
Ive never done it, but from what i'm told you can put type F in a trans built for mercon. The type F will cause the trans to shift harsher, but from what i'm told, this is an old school trick used by racers, ... kinda the poor man's shift kit.
i'd just use mercon.
Old Dec 31, 2011 | 11:21 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Real men use Type F.
If grandma wants a soft shifting grocery getter she would use Dexron/Mercon.
Josh
Old Jan 1, 2012 | 08:02 AM
POPAJON's Avatar
POPAJON
OK just a question........Has anyone used Royal Purple in their trannys? Given all the hype on the synthetics I would venture to ask this. john
Old Jan 1, 2012 | 09:13 AM
Bullitt390's Avatar
Bullitt390
I would use RP if it were given to me, Redline too. But I wouldn't pay for it.
Josh
Old Jan 1, 2012 | 10:56 AM
meborder's Avatar
meborder
Josh
this is quite simply the most idiotic advice ever given in the whole history of FTE.
Owners manual says Merc ... that's the correct fluid. period.
Old Jan 1, 2012 | 11:04 AM
Bullitt390's Avatar
Bullitt390
After you just stated somewhat the same thing in regards to Type F?
You have some serious issues, it won't be long before your banned with such a negative attitude.
If you knew the real history of why Ford chose to go with a slicker/ softer shift versus the better and firmer Type F shift you would understand it makes no difference.
If Chevy's slushbox is smoother, although less efficient Joe Blow or Soccer Mom Nancy who test drives a Chevy then a Ford will likely choose the Chevy.
What's Ford going to do? Join the crowd that's what.
Type F only applies to the COM, FMX, C4, C6. Nobody is going to use or should use Type F in a modern transmission.
Josh
Old Jan 1, 2012 | 11:15 AM
fmc400's Avatar
fmc400
MSEE
What?! You just said that you read it would work. I know you qualified it by saying you haven't tried it yourself, but Josh's follow-up was hardly the worst post on FTE (believe me there have been some bad ones).
I personally don't have experience with the differences and use whatever is written on the dipstick or written in the manual.
Ford SD
27
Jan 17, 2018 02:59 PM
61 uni
Oct 6, 2012 04:01 PM
KraZeDav
Oct 30, 2010 01:30 PM
Bowtie_Schmowtie
Jun 8, 2009 01:30 PM
78fordman
Mar 10, 2004 09:26 PM
