reverse engineering
Old Nov 19, 2010 | 02:07 PM
parkers5150's Avatar
parkers5150
reverse engineering
so i'm new to both site, and in depth mechanics. what i have is an 89, e-350, 460, c-6.i just purchased the van and upon driving it home the (what it felt like was) the tranny disengaging. since I'm no mechanic i figured tranny filter and fluid change. everything is done (thanks to members here) except for refilling the tranny. My problem is that in the procees of refill iv\'ve yet to get a clear reading on the dipstick (it's all over the stick with no clear indicator of level) Sooooo being the mechanical genius that i am i have poured the old fluid back into the new bottles and we're pretty close to even steven. my concern is that what if the level was low to begin with and why can i not feel good about reading the stick
Old Nov 19, 2010 | 02:24 PM
parkers5150
UPDATE: tried to drive the van wont engage in any gear drive, reverse, 1 or 2 ??????
Old Nov 19, 2010 | 06:45 PM
Ford_Six's Avatar
Ford_Six
You have to let the fluid drain down the tube before it'll show the correct level. Start the engine, shift the lever through all positions and then back to park, then check the level. If it's not at the right point, add more, shift it through the gears again, and check again.
Old Nov 19, 2010 | 07:05 PM
parkers5150
i did that. ran it through the gears a few times. decided to take a short put and couldn't get to the end of the driveway
Old Nov 19, 2010 | 10:53 PM
stuart1's Avatar
stuart1
It doesn't matter how much you took out, but how much you actually need.
There is a breather on the transmission and if it gets clogged you will have a high reading on the stick yet the transmission will be very low.
Look at the breather first.
Old Nov 22, 2010 | 09:07 AM
parkers5150
anybody want to help?
Old Nov 22, 2010 | 02:09 PM
stuart1's Avatar
stuart1
Did you do as I suggested?
Old Nov 22, 2010 | 03:43 PM
parkers5150
Stuart, can you describe the breather and where it is located?
Old Nov 22, 2010 | 04:06 PM
parkers5150
also Stuart can you tell me the best way to troubleshoot and clear the breather please
Old Nov 22, 2010 | 05:33 PM
stuart1's Avatar
stuart1
It is located on the case just above the front cooler line.
A small cap may or may not be visible, depending if there is any mud n stuff.
When it is plugged the fluid level will show full yet still be very low.
emmagator
Oct 29, 2013 06:23 AM
DISLFVR
May 11, 2013 07:38 AM
Blue and White
Jan 1, 2012 11:15 AM
sigtauenus
Apr 2, 2010 11:30 AM
fitzy67
18
Jan 31, 2010 10:21 AM
