What are the 5 best mileage improvements for 460
Old 01-06-2014, 10:12 PM
flaboy1979's Avatar
flaboy1979
flaboy1979 is offline
Only way I found is not drive the gas guzzling beast
  #62
Old 08-01-2016, 01:29 PM
bulldog 123's Avatar
bulldog 123
bulldog 123 is offline
I had a gm 454 one ton , well put me in the poor house,
now run Ford one ton 460
  #63
Old 08-01-2016, 07:34 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
poverty; it's a vicious cycle.
  #64
Old 08-02-2016, 06:12 PM
Phil Woolfson's Avatar
Phil Woolfson
Phil Woolfson is offline
Originally Posted by Old93junk
A F-250/350 with a 460 is not a daily driver............Its a piece of heavy equipment. Do not expect to make the mpg bearable for such duty, its just not going to happen.
Consider a Kia to drive when you don't need the truck.
The only thing I have found that helped even very slightly was going to long tube headers, took me from 11.5 to 12.5.........that is after I quit exploring the new found performance bump.
Umm, yes, it is.
  #65
Old 08-02-2016, 06:17 PM
Phil Woolfson
I put in a throttle body spacer, did a shorty exhaust, keep well tuned, have replaced a lot of 27 year old sensors, injectors, dizzy, cap, wires proper copper plugs. Regular additives, seafoam, throttle cleaning, oil and gear case changes and run 93 oct.Tires 75# / 65#. Mileage typical between 12(stop&go) - 14 longer trips. I have a cab height cap, which helps.
cowboyacg
6.7L Power Stroke Diesel
10-10-2016 02:14 AM
jep
20
09-21-2016 05:44 PM
sktobias
05-09-2016 04:05 PM
TheLordOfDeer
03-20-2016 12:31 AM
jdstag2
Idaho Chapter
03-07-2016 07:53 PM
Quick Reply: What are the 5 best mileage improvements for 460
