1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
Installing Explorer seats, console and OH console
Old Jan 21, 2004 | 12:54 PM
johare's Avatar
johare
Talking Installing Explorer seats, console and OH console
I just finished an installation of a set of 2000 Explorer power leather seats, a 2001 Explorer floor console and a 1999 Explorer overhead console in my 1999 Ranger XLT X-cab. Everything went very smooth. See this thread for more information https://www.ford-trucks.com/forums/s...hreadid=181972
I can also send detailed information with photos via e-mail if anyone is interested.
Old Jan 21, 2004 | 03:48 PM
Rockledge's Avatar
Rockledge
Hey, that's great!
I haven't really thought about doing something like that before but it sounds pretty darn cool.
I would be very interested in some detailed instructions and photos, in any case. Can't post email addresses here, so you'll have to go to my profile and contact me that way...
Old Jan 21, 2004 | 03:58 PM
AG4.0's Avatar
AG4.0
You need to post some pics, that sounds awesome.
Old Jan 21, 2004 | 04:01 PM
johare's Avatar
johare
Adam,
Will do as soon as I can scan the photos. Probably this weekend. I hope to create a gallery with some photos in that.
Old Jan 21, 2004 | 08:11 PM
Ken00's Avatar
Ken00
When your done I can make a link in the tech info post.
Old Jan 21, 2004 | 08:18 PM
Nightrain's Avatar
Nightrain
I was thinking the same thing.I bet that looks really cool.
Good luck with your new edition johare !!
Nightrain
Old Jan 22, 2004 | 08:53 PM
johare's Avatar
johare
Detailed information on seat and console installation
As promised here is detailed information with pictures of the installation of the Explorer power seats and center console in my Ranger.
NOTE: I am not sure how to get the photos to post. You can see the completed seats and OH console in my gallery.
Installing Explorer seats and center console
1999 Ranger XLT Sport X-Cab with 60/40 seats
New seats: 1999 Ford Explorer Sport 2dr
Console: 2001 Ford Explorer Sport 2dr
Process:
1. Removed original seats and middle seat belts.
2. Removed ashtray and passenger side air bag switch. Removed the air bag switch from its bracket and temporarily fastened it under the dash. The switch could be mounted in the new console but since I never turn the passenger air bag off I left it under the dash (held with plastic ties). I can access it if necessary by removing the front panel of the new console.
3. The dash is predrilled for the alignment pins and bolts for the Explorer console. (Photo #1)
4. Pull back the carpeting. You will have to remove the threshold plastic which is held in by clips. Just pull it loose. I also removed the plastic panels on the kick panels.
5. The console I got has a metal mounting bracket that mounts to the driveshaft hump and two metal tangs on the console slide into slots in the bracket to secure it. (Photo #2)
6. Position the console where it should fit with the mounting bracket in place and mark the mounting bracket mounting holes.
7. Remove the console and drill holes for mounting the bracket. I used ¼ inch sheet metal lag bolts that were ¾ inch long. Be sure to check that you are not drilling into a gas tank or other important object under the cab!
8. Place the carpeting back over and cut out a hole just large enough to expose the mounting bracket. (Photo #2)
9. Now you are done with the console except for sliding it in place.
Seats
1. You may need to do some pre-work. My seats came out of a ’99 Explorer Sport so they tilt forward. The seat tracks on the Explorer seats fit exactly to my Ranger mounting holes. However the seat belts were different. The female seat belt ends from the Explorer seats would not latch with my Ranger male ends so I removed the female seat belt ends from my 60/40 Ranger seats and mounted them on the Explorer seat belt tracks (the Explorer female seat belt ends mount on a track that fastens to the inside track of the seat but also to the truck floorboard.) (Photo #3)
2. For wiring, I ran a power wire (I used #12 wire) from the cigarette lighter to the drivers seat. This will enable the seats to be adjusted with the ignition switch off. The cigarette lighter is already fused to a 30 amp fuse which is what Explorer uses for power seats.) I ran a ground wire (#12) from the grounding bolt located behind the left kick panel. These wires ran across the floor and into the wiring loom on the driver’s side of the cab. (Photo #4)
3. Replace the carpeting. You will want to run a length of power wire and ground wire under the carpeting from the passenger side to the drivers side if your passenger seat requires, power as mine does, before replacing the carpet.
4. I now installed the console since I thought it would be easier than trying to do it with the seats in place. Since my passenger seat has power lumbar, I spliced a power wire and ground wire into the power connector of the passenger seat with crimp connector. Had I had an extra Ford two wire quick connector I would have used that to make seat removal easier.
5. I mounted the passenger seat to the floor of the cab with the original Ranger mounting bolts. I had to drill out the seat track mounting hole just slightly on the inside mount as the Ranger bolts were slightly larger. The passenger seat power wires were snaked under the carpeting to the driver’s side where they will connect to the driver’s side power line.
6. I then connected the main power and ground from the truck and the power and ground from the passenger seat to a two wire quick connector.
7. Then I bolted the driver’s seat in place using the original ranger bolts. Again had to drill out one mounting hole in the seat track mounting foot and connected the power quick connector to the driver’s seat power.
8. I connected the seat belt warning connector to the original connector used in the Ranger 60/40 seats. (Photo #5)
9. The seat belt mounting was a bit more involved. I made a mount from a piece of 3/16 x 1 ½ inch angle iron for each side. I used ½ inch stainless bolts and locking nuts to mount the Explorer seat belt bracket to the angle iron. I then drilled a hole in the other side of the angle iron to accommodate the bolts from the middle seat belts from the 60/40 seats. This I bolted in its original hole to the floor pan. (Photo #6)
10. Photo #7 shows the completed set-up with seats and console.
Installing an Overhead Console from a 1999 Explorer
These two links give very detailed information on overhead console installation.
http://www.explorer4x4.com/overhead.htm
http://www.generation-edge.com/forums/ohc.asp
Here is a photo of the completed console.
Old Jan 22, 2004 | 10:15 PM
johare's Avatar
johare
I posted the photographs that go with this write-up in my gallery!
Old Jan 22, 2004 | 10:43 PM
Rockledge's Avatar
Rockledge
Excellent instructions! Thanks for taking the time to post them.
For some reason the larger pics from your gallery do show up clear on my screen...
Old Jan 22, 2004 | 10:53 PM
johare's Avatar
johare
I know, the large format is fuzzy. I need to work on that. I scanned the photos from color photos rather than from a digital camera. I will see what I can do to correct that.
Old Jan 23, 2004 | 07:39 AM
johare's Avatar
johare
Hey Rock!
I got the photos fixed so they are clear thanks to Mil1ion's expert advice.
Check them out!
Old Jan 23, 2004 | 09:47 AM
Rockledge's Avatar
Rockledge
Originally posted by johare
Hey Rock!
Check them out!
Yep, the pics do look great now...
Old Jan 23, 2004 | 12:08 PM
Ken00's Avatar
Ken00
Thanks, added it to the tech info post.
Old Jan 26, 2004 | 09:16 AM
johare's Avatar
johare
Ken00,
I checked the tech info post and the link took me to a different thread. I think there is a error in the link.
Old Jan 26, 2004 | 08:03 PM
Ken00's Avatar
Ken00
I think I got it right this time, Thanks!!!
