PATS system distress
Old Yesterday | 08:54 PM
mtymartin's Avatar
mtymartin
4th Gear
2011 E250 van with 4.6. System distress. Started at church "no crank no start". checked voltage, good. Bypassed starter with key on, START! Drive home, shut down and retry. Dead. retried bypass start, zip. But now all of a sudden flashing security lights from the PATS. I do not have chipped keys. Most models do I guess but I read many fleets ordered w/o PATS. I have tried 6-10 different methods out there to sort of reprogram or clear the fault. Zippo. A friend, old key man tried his scanner, no good. Made me extra keys though! I read that one cannot bypass the system though because it is permanently in the software of the BCM or the PCM, otherwise I would bypass it and go on. I checked every fuse, didn't expect much and didn't get much either. Checked all relays, good. I really don't have much money but this is my work van. Any old pros out there with ideas? Where can I get a diagram of the PATS system. Anyone got one out of a chiltons or Haynes?
Old Yesterday | 09:13 PM
Don Ridley's Avatar
Don Ridley
PATS is located in the IPC (cluster). Here is a link to the service manual. I navigated to the DTC chart. You need a scan tool like Forscan to read DTCs. Forscan can also do Parameter Reset. But be warned, PATS has stumped many DIY users and sometimes it takes a lot of research to learn how to fix it. I am no expert....just have seen a lot of posts regarding PATS.
https://lemon-manuals.la/Ford/2011/E...20DTC%20Chart/
BigPoppaJD
15
Apr 25, 2024 07:14 AM
edford1
1997 - 2003 F150
Aug 11, 2012 11:14 PM
53ford53
2004 - 2008 F150
Aug 22, 2010 07:53 PM
goethemom
1997 - 2003 F150
Aug 22, 2010 02:15 PM
Ranger354
1997 - 2003 F150
24
Dec 7, 2006 06:01 PM
