2006 Security system prevents start ??
Old Aug 22, 2010 | 11:00 AM
53ford53's Avatar
53ford53
Question 2006 Security system prevents start ??
Does anyone have any experience with the security system. Specifically, I'm trying to understand what exactly will trigger a security system shutdown and what the owner can do to remove the shutdown?
It would seem unreasonable to need to have road side assistance or trailer it to a dealership to release the shutdown.
Thanks,
Old Aug 22, 2010 | 11:39 AM
screwy's Avatar
screwy
Using an un-programmed key is the only way it'll trigger, aside from a breakdown in the system somewhere. It's main functionality is internal to the ECU, only thing you could do is see if you can get a custom tune to disable it.
Old Aug 22, 2010 | 11:44 AM
goethemom's Avatar
goethemom
Hello 53,
I have a 99 150 Lariat that seems to have the same problme. From what I read
online is its not a simple thing to just bypass the system. Nor does the dealer want
you to. The dealer has a scanner to check the system, to see exactly where the
prblem lies. It could be as simple as a new key, but then the dealership may be
inevitable. Im trying to find out myself. I hope someone seesyour post and can be
of some help. good luck
Old Aug 22, 2010 | 11:48 AM
53ford53's Avatar
53ford53
The original key was used. Drove for 20 minutes, shut it down, 40 minutes later tried to start with the same key and it would not. Roadside assistance cleared the security event, and then it was fine.
Had one of those OBDII scanners/mileage computers plugged in and the belief is that this is what caused the security event. But there is no hard evidence. I have never read anyone else having a similar problem.
Old Aug 22, 2010 | 07:24 PM
bridge's Avatar
bridge
Sick 'n Tired
I seriously doubt the scanner caused the secruity event. What codes did you get?
Old Aug 22, 2010 | 07:29 PM
53ford53's Avatar
53ford53
No codes, the OBDII device was being used as a mileage computer. All worked great as I described above, until the security event was set.
I see you have a 2006, do you have and OBDII device on yours?
Old Aug 22, 2010 | 07:53 PM
bridge's Avatar
bridge
Sick 'n Tired
Yup, I've got an Edge.
n3hcp
6.7L Power Stroke Diesel
17
Mar 21, 2014 09:50 AM
HT32BSX115
Jan 29, 2014 09:12 AM
lexustbs
15
Nov 4, 2010 09:23 AM
ChiefGReid
Dec 11, 2004 06:57 AM
