Help - Pitman Arm Removal
I am trying to remove the pitman arm from the steering gear; I have a front end tool set with a "proper" pitman arm puller. The pitman arm is right up against the steering gear; there is no room to get the removal tool underneath the arm. What should I do ?
Some background:
1) My steering gear was leaking, and for a quick (ie I will rebuild it whenI have time later) and cheap fix I got another steering gear off a junkyard 1994 E-250. The gear from the junkyard is the exact same part number as my steering gear; however, the pitman arms are different.
2) I am trying to take the pitman arm off my original gear to put on the junkyard gear. The pitman arm that is on the junkyard gear has some space between the gear and arm to get the removal tool properly underneath, but the gear out of my van has zero space to fit the tool.
What gives ?
Here is a picture of the steering gear from my van, notice how snug the pitman arm is to the gear:
Pitman arm removal tool
That will lower the sector shaft in the gear housing and give you the clearance needed for the tool
Also,
If you hit it hard enough with a big hammer in the right spot, it will pop off of there too
Also,
Thanks for the advice, so to be sure the sector shaft is that which is in the direction of the pitman arm (ie NOT the input shaft, which is perpendicular to the sector shaft ?
