Lift Pump Perhaps?
Old Apr 28, 2026 | 04:31 PM
jktrevecca's Avatar
jktrevecca
Lift Pump Perhaps?
Hi there! I have a no fuel to the filter housing problem. Originally convinced it was the selector valve, I replaced it. Things worked for about 100 miles, then truck died so I bypassed the tank selector valve and got her home. Next day... no start at all. Pulled the line going into the filter housing and cranked the truck - NO FUEL PULSING/COMING OUT. Then.... I attached a 3/8" line to the intake side of the lift pump and put the other end in a container of diesel. Cranked and still no fuel.
Should my lift pump have the ability to suck air strong enough to pull the fuel out of that container or do I need to prime it somehow? I don't want to waste time and money replacing the lift pump until I know for sure that's my issue.
Thanks in advance!
Old Apr 28, 2026 | 08:59 PM
tecgod13's Avatar
tecgod13
"lift" pump, its right in the name....
So yes, the point of the lift pump is to suck the fuel from the tank and lift it up to the injection pump, which them pressurizes it for fuel injection. If your lift pump won't suck out of a container of fuel presumably on the ground next to the engine, then its dead.
Sounds like you pulled off the line from the lift pump to the filter housing, did you check if it was blocked?
The mechanical pumps have been getting worse over the years, they may be crap right out of the box. Many people switch to an electric lift pump and remove/block off the mechanical pump. While many options are out there, Facet Duralift pumps are well known for being reliable and the most recommended for our engines. You'll want to get the Facet 40222, Aircraft Spruce is often mentioned as the cheapest place to get one. I have heard their may be fakes floating around ebay and amazon, so beware.
https://www.aircraftspruce.com/catal...statepump2.php
Old Apr 29, 2026 | 07:32 AM
tjc transport's Avatar
tjc transport
i ain't rite
also check engine oil for overfull. when the lift pump starts to fail, it tends to dump diesel fuel into the engine oil.
Old Apr 29, 2026 | 08:47 AM
gespeter's Avatar
gespeter
I bought the Facet and it is beyond excellent.
Yellow goes on B+ lug on starter solenoid
Black ground
White ties into harness to lead that powers fuel solenoid on IP.
Red/Blk pair connect to pump
Inlet is 1/8" npt x 3/8 90° barb
Outlet is 1/8" x 3/8 45° barb....45° works perfectly
Another 3/8" 90° barb on filter head (cant remember pipe thread size)
​​​​​​Hose is 3/8 AN-6 braided
Clamps are fuel injection style, not worm clamps
Standard Bosch style relay and 10amp fuse
Mounted on L bracket right next to corner of metal tray on top of fender liner. Relay mounted there also. It all just fits and will allow fuel to drain down without getting on anything if I need to clean strainer.
The only caveat is I now have something electrical that could conk out, so I'll keep a spare on board. Facet is more reliable than the crummy mechanical we're getting nowadays anyway...
BTW throttle response seems a little snappier as well.
Old Yesterday | 09:31 PM
Binky7.3's Avatar
Binky7.3
This is on my list of 'to dos' on Binky.
Pegasus sells them $25 cheaper than Aircraft Spruce...
https://www.pegasusautoracing.com/pr...asp?RecID=9705
They specifically mention it for our trucks.
wahlturfcare
Apr 29, 2026 05:03 PM
freightdogfred
May 10, 2021 08:08 PM
katman104
Mar 21, 2018 07:40 AM
Lysandra
16
Jan 11, 2018 09:37 AM
texasjack
Dec 9, 2008 09:24 PM
