Leveling variable rate coils? For gas truck?
I will be doing a lot of front end work on my 09 350, replacing rusted through spring pockets, and replacing the old rusty coils while I am at it. I've often thought of a leveling kit, and if I need to replace the coils anyway I'd much prefer just buying lift coils instead of stock coils + spacers. Variable rate coils that might make this tank ride a bit softer would be nice. Everything I am seeing is for diesel trucks though? Anyone have any leads on +2" or 2.5" variable rate coils? Would a heavy fabricated bumper + brush guard make the diesel springs more applicable? I currently have TT code springs / 5200# F GAWR
Thanks!
Thanks!
I did a fair amount of research when contemplating lifting/leveling the front of our 2wd gasser. While the 4wd springs are physically different than the 2wd, and incompatible, I believe I understood that the 4wd springs were compatible, save for that extra weight of the diesel engine. That extra weight on the nose (or say like a plow hangin off it), should get you close enough to "work". Obviously, it's not going to ever ride like a caddy, but if you can determine the approx difference in your V10 vs. a 6.4, you know what you need to "make up"
Back in the 2009 or so, one of the hot rodding TV shows purchased an F-350 DRW 4x4 with a PSD, for a shop truck and tow vehicle. They were mounting a Ranch Hand bumper on the front and were concerned about the front suspension sagging. They measured 1/2 inch sag after the bumper was installed.
Don’t worry about the sag, unless you don’t like the look. Then, figure out how to fix it.
I'm currently running Icon 4.5" dual rate coils in my truck. I ran them when my truck was still a 5.4 and it rode better than stock then. When I did the diesel swap I swapped to Pro Comp 6" springs and noticed a much harsher ride and quickly switched back. I was running Fox 2.0 monotube shocks when it was a 5.4 and now I'm running Bilstein 5160 in all 4 corners and couldn't be happier with the ride.
Last I checked rough country had a set of 1.5” coils that said compatible for gassers. I originally was going to do the same thing but I changed my mind when I had trouble finding compatible coils for a 4x4 6.2. I’m planning on a 4” lift with coils from a complete kit.
So it feels like I'm spinning my wheels here for the past week. I've sent out emails to a few manufacturers & dealers. Half of them have never been responded to me after a week. Usually thats an automatic strike from my list, however some of the ones that did not respond seem well regarded here, like PMF.
Speaking of PMF I noticed they sold Icon dual rate springs with much lift options than I thought Icon made? Maybe when I saw 2.5", 4.5" and 7" at https://www.iconvehicledynamics.com/ that is not actually Icon but perhaps just a dealer that doesn't carry everything? But PMF shows Icon dual rates in 1.5, 2.5, 3.5, 4.5, 4 at https://www.pmfsuspension.com/2005-1...oils_p_46.html
Maybe the Icon dual rate 1.5" diesel springs would give me the ~2" ish and perhaps softer ride (or at least not stiffer) that I am looking for in my v10 with potential heavy fabricated bumper?
If I do that, do I need the caster cams? They come with the springs like the 2.5" from https://www.iconvehicledynamics.com/...Dspring%2Dkit/ but the PMF Icon springs have no mention of castor cams.
skyjacker f520, 2" lift in softride, not variable rate. Many people (likely those with a towing package) report it didn't lift the front at all, If you feel yours had a towing package or a plow package then bump it to the f540, which is the 4" softrides. the 540's lifted my 09 about 1" above plow prep diesel springs on a 5.4 truck and it rode alot better, but the air bag conversion rides 100x better than any coil setup I tried
I'm not looking to jack it all up, but since my coils are really rusty and I am re-doing much of the front end, I figure its a good time to replace the coils and if I can level it then great. I'm leaning towards the Icon 1.5" springs. If it ends up being stock height I could always add a spacer, but I'd prefer to get the work over and done with in one shot.
All this uncertainty in lift height also confuses me on which castor cam to get also....
Appreciate the heads up though. I don't know why Bilstein is so hard to search, even when I typed Bilstein levelling kit thier own website didn't come up on the first couple google pages, and most of the links even when I put their part number were taking me to lift kits for dodge rams and such!
Seems like the usual places don't carry this part for some reason, most the sellers I've not heard of. Anyone use these guys before?
https://www.suspensionlifts.com/shop/ford/f250/bilstein-5112-2-inch-front-0-1-inch-rear-levelling-lift-kit-shocks-2005-2016-ford-f250-4wd/?srsltid=AfmBOoo2RITRm3rPVO7mYNuaok5fQNbBAQKK6a99-0x87nzRq6oYZ24gG54
Rusty_S
13
08-08-2016 07:40 PM
