Leveling kit - options
I see LMC sells springs that they claim do not change the ride quality. I also found spacer blocks that I figure go between the spring and the I beam itself.
Are there other options other than those two?
I ask because my truck rides kind of rough and harsh unloaded so I am really looking at having Eaton make me springs front and rear to OEM specs and see if they will improve the ride quality. I also am thinking of just having him make the coil springs like a leveling kit coil spring. But I need to see the quote he gives me on two coils and two leaf springs. Rather have them built to oem specifications vs buying some generic stuff that you pick up from the local auto parts store.
Thing is though I really don't care for the leveling aspect I am only looking at it cause the KO2 tires I have, have an aggressive shoulder that hits my plastic inner fender on some very hard bumps and figured a simple spring swap for new coil springs would not stop this from happening. Didn't have the problem with the Pathfinders I had before nor the KO1 tires but since KO1 is obsolete now and only KO2 are being made I am stuck with this
I'm happy with them so far
When I bought my first new truck in 86 and wanted HD springs (diesel truck for towing trailers) the salesman said "you know it will ride ruff?" I told him "yes I know it's a truck not a car!"
I did not think it rode ruff, and it had factory duel shocks up front also.
My grandmother rode in it from Raleigh, NC to CT and said she was surprised it rode so nice.
I think for you to get the ride you want you will have to go custom made. Maybe one of them progressive type spring? It will smooth out the little bumps but when you hit the heavy ones the other part of the spring comes into play to keep from bottoming out.
Dave ----
I know Eaton can build custom springs but I just want it to ride like it did when new I just don't think a short wheel base single shock truck is going to ride rougher than say a new dodge 3500 truck and I drive thoses all the time when I do work on them at work for the wrecker company and thoses ride rough but no wheres near where mine rides at.
Now the leveling aspect I am looking at that because the KO2 tires I have they keep scrubbing my plastic fender well and they are the same size as the KO1 I had previously and the discount tire brand pathfinders and they scrubbed just a little but you had to hit the bumps that was big at around 40 or 50 mph theses scrub at even 25 to 30 mph on them so I figured raising the front up via leveling kit might actually stop this as LMC claims it allows the use of 33" tires on these trucks and mine are just 31x10.50-15.
I ask cause i put a 80lb battery in the back and the truck sat down some. Wondering if my leaf springs are weakened or if the new ones will work the same?
Pic from when I first got the truck to Ohio. Replacing the stabilizer pin busings helped by leaps and bounds.
But the truck does squat fairly easy I just wonder if its worn out leaf spring bushings or if its the springs are weak itself.
I know the truck does seem to ride smoother if I have the back squatted down some with weight in the back but figure that is normal for any leaf spring truck.
If new springs are out of reach, maybe a set of Adjustable Coil-Over shocks would be a "happy medium", firming up the butt-end. That along with your idea of new front springs just might smooth things out. Keep in mind that the coil-over's will raise the rear a bit. I know it's a totally different animal but, when i had new springs built for my '97 Ranger (due to a FoMoCo known spring breakage issue) and installed the coil-overs, it raised it approximately 3 1/2 inches over stock ride height. But, my Ranger is a Flareside with plastic bed sides and is much lighter. Bed empty, i had to install a rear stabilizer to stop "rear hop" but i can haul a fair amount of weight in a 1/4 ton truck.
Now on the leafs, mine is just like the photo above except I do not have the curved helper spring at the top. I stepped on the back bumper and with my 200 - 220 lb self the truck squatted on one side down a good 2 to 3 inches. Not sure if this is normal or not but the truck did haul a heavy trailer for a few years as a work truck when we had it. Before that I don't know. But I figure with me doing ball joints I want to do springs and everything if it needs it. The leveling kit I been throwing around to raise the front some to stop the new KO2`s aggressive shoulder from scrubbing my plastic fender on the passengerside (its just the passengerside) when I hit dips in the road at any speed over 25-30 mph.
In the end if my springs are functioning as they should be I wont replace them. I just figured I would look into this and do the leveling kit. Instead of going with the spacers I could get Eaton to make me some coil springs like the LMC ones that are taller to give me the leveling without use of spacers and I can rest easy knowing the springs are made to have the same specs as the stock height springs. I thought of doing the plastic spacer thing but not exactly sure how thoses will work but it would be easier though as for $50 if the camber cant be set I could always pull them out again and no big deal. Harder to do that with a pair of $150+ coil springs.
Well I am thinking on it and the more thinking I am doing, I am leaning towards not even doing the leveling kit. Some people had problems of getting camber in the green with even a 1 1/2" leveling lift being done. Like wise as was stated above the rear springs are designed to be soft and settle easily to prevent the front from being higher than the rear. Well doing a leveling will negate this. I am how ever wondering if I need to atleast check the rear bushings. I don't think this truck has as many miles as the one I did the 5.0 swap on but that one he wore through the bushing and through part of the spring eyelet. I already did bushings in the I beams, also replaced front shocks. So if everyone agrees that the springs don't sound worn out or that I wouldn't benefit from the cost of replacing the springs front and rear then I think I will just go for replacing the ball joints as they pop when cold weather sits in and they are original to the truck. That coupled with having an alignment done might stop my passengerside tire from scrubbing the plastic inner fender.
