Hello I have a 92 ford f150 5.0 v8 and I recently lost the power steering and its only slightly turning to the left but nothin else no more and it's whining louder then the engine and bogging it down I don't know whats binding because I put In a junkyard gear box but I don't know what it is can somone help me please
You just put in a junkyard gear box and the system is full? I'd wager it needs to be burped. Put the front end up in the air (tires off ground), take the PS cap off and run the steering wheel lock-to-lock about twenty times or so.
2 turns of play? Junkyard gear? Go get another one!
Ouch
The roll pin in the control valve (inside the steering gear) is sheared
Tear into it
You are smart enough to overhaul a steering gear
