1975 f-100 power steering gear box change
Old Oct 8, 2005 | 05:45 PM
upsfordman's Avatar
upsfordman
I Have A 1975 F-100 4x4. I Want To Change Over The Ram Assisted Steering To Real Power Steering. Any Suggestions????? I Was Told That Power Steering Gear Box Out Of 77-79 F-150 Or A 77-79 Bronco Would Be A Direct Replacement. This Is Not So.
Old Oct 17, 2005 | 06:07 PM
73 ford guy's Avatar
73 ford guy
if its a solid front axle i would use a 2wd steering box from the same year and mount it in the inside of the frame rail.
Old Oct 19, 2005 | 11:31 AM
73Custom's Avatar
73Custom
There are a couple tech articles about 4x4 power steering swaps, check them out. Under the 'Articles/Specs' link at top of page.
Marty
Old Oct 19, 2005 | 12:42 PM
1975Ford's Avatar
1975Ford
Power steering gear box off a 1976 - 1979 Ford F150 4x4 will fit nicely or a 1978 - 1979 Ford Bronco, will need to drill holes to bolt on the gear box, and also will need to weld fill the place where on the front mounting holes on gear box to make the gear box sit flush on frame rail.
Does your truck have disk brakes?
Need to find the power steering bracket and pump and power steering hoses, off a truck with the same engine size as your truck engine, This will help to power up the power steering gear box.
Also need to modify or find a power steering shaft from the steering column to the power steering gear box.
"All the hard work will pay off when you get the power steering working."
__________________
"1975Ford"
1975 Ford F150 4x4 4speed, 390 cid from 67 Galaxie
1975 Ford F250 4x4 4speed, 400 cid from 81 F250
1976 Ford F150 4x4 4speed, 360 cid 30 over
1978 Ford F150 4x2 4speed, 302 cid stock
xringonly
1966 - 1977 Early Broncos
13
Jan 15, 2014 06:31 PM
telefunkken
WTB - Parts & other
Aug 6, 2013 02:50 PM
upsfordman
Oct 8, 2005 11:21 PM
larbuck
Nov 29, 2001 01:08 PM
