Hello
May 6, 2024 | 09:16 AM
4wd High
Hello
Hello I have a 92 ford f150 5.0 v8 and I recently lost the power steering and its only slightly turning to the left but nothin else no more and it's whining louder then the engine and bogging it down I don't know whats binding because I put In a junkyard gear box but I don't know what it is can somone help me please
May 6, 2024 | 10:27 AM
Is the steering system full?
May 6, 2024 | 10:40 AM
4wd High
Quote:
Originally Posted by
Hit Man X
yes it's filled it does suck it down but I top it off there's no leaking either
May 6, 2024 | 10:58 AM
Klutz
It is full with the engine off? Air bubbles in the fluid?
What do you mean by “it’s only slightly turning to the left but else no more?”
May 6, 2024 | 11:10 AM
You just put in a junkyard gear box and the system is full? I'd wager it needs to be burped. Put the front end up in the air (tires off ground), take the PS cap off and run the steering wheel lock-to-lock about twenty times or so.
May 6, 2024 | 11:32 AM
4wd High
Duke5A
I'll try that and engine off right
May 6, 2024 | 11:35 AM
4wd High
My4Fordtrucks
like it turnt but not far and I go to steer right and it doesn’t it stops and the tire is straight
May 6, 2024 | 01:58 PM
Klutz
After replacing the steering gear did you bleed the system or not?
Klutz
Did you make sure the steering gear was centered before installing the pitman arm?
May 6, 2024 | 02:27 PM
4wd High
My4Fordtrucks
I did when I was taking the other one off
the pitman arm was already on
May 6, 2024 | 02:53 PM
Klutz
So you made sure the box was centered before installing the steering linkage? Your wheels were also straight?
May 6, 2024 | 06:14 PM
4wd High
My4Fordtrucks
yes I did but when I turn it it has alot of play like 2 turns worth of play which is so odd to me
May 7, 2024 | 05:05 AM
2 turns of play? Junkyard gear? Go get another one!
Ouch
The roll pin in the control valve (inside the steering gear) is sheared
Tear into it
You are smart enough to overhaul a steering gear
May 7, 2024 | 05:06 AM
20 turns lock to lock with the front wheels elevated is how you bleed the air out of a PS system
Go slow
Woodie49
Dec 3, 2023 02:45 PM
Reborn84f150
Jun 9, 2023 06:46 PM
brenthottle
Jul 11, 2014 06:02 PM
upsfordman
Oct 19, 2005 12:42 PM
