Hello
Old May 6, 2024 | 09:16 AM
Klutz's Avatar
Klutz
4wd High
Hello
Hello I have a 92 ford f150 5.0 v8 and I recently lost the power steering and its only slightly turning to the left but nothin else no more and it's whining louder then the engine and bogging it down I don't know whats binding because I put In a junkyard gear box but I don't know what it is can somone help me please
Old May 6, 2024 | 10:27 AM
Hit Man X's Avatar
Hit Man X
Is the steering system full?
Old May 6, 2024 | 10:40 AM
Klutz's Avatar
Klutz
4wd High
yes it's filled it does suck it down but I top it off there's no leaking either
Old May 6, 2024 | 10:58 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It is full with the engine off? Air bubbles in the fluid?
What do you mean by “it’s only slightly turning to the left but else no more?”
Old May 6, 2024 | 11:10 AM
Duke5A's Avatar
Duke5A
You just put in a junkyard gear box and the system is full? I'd wager it needs to be burped. Put the front end up in the air (tires off ground), take the PS cap off and run the steering wheel lock-to-lock about twenty times or so.
Old May 6, 2024 | 11:32 AM
Klutz's Avatar
Klutz
4wd High
I'll try that and engine off right
Old May 6, 2024 | 11:35 AM
Klutz's Avatar
Klutz
4wd High
like it turnt but not far and I go to steer right and it doesn’t it stops and the tire is straight
Old May 6, 2024 | 01:58 PM
My4Fordtrucks
After replacing the steering gear did you bleed the system or not?
Did you make sure the steering gear was centered before installing the pitman arm?
Old May 6, 2024 | 02:27 PM
Klutz's Avatar
Klutz
4wd High
I did when I was taking the other one off
the pitman arm was already on
Old May 6, 2024 | 02:53 PM
My4Fordtrucks
So you made sure the box was centered before installing the steering linkage? Your wheels were also straight?
Old May 6, 2024 | 06:14 PM
Klutz's Avatar
Klutz
4wd High
yes I did but when I turn it it has alot of play like 2 turns worth of play which is so odd to me
Old May 7, 2024 | 05:05 AM
manicmechanic007's Avatar
manicmechanic007
2 turns of play? Junkyard gear? Go get another one!
Ouch
The roll pin in the control valve (inside the steering gear) is sheared
Tear into it
You are smart enough to overhaul a steering gear
Old May 7, 2024 | 05:06 AM
manicmechanic007
20 turns lock to lock with the front wheels elevated is how you bleed the air out of a PS system
Go slow
Woodie49
Dec 3, 2023 02:45 PM
Reborn84f150
Jun 9, 2023 06:46 PM
brenthottle
Jul 11, 2014 06:02 PM
upsfordman
Oct 19, 2005 12:42 PM
