Rear Leaf Spring Options for 54
People always speak well of Posie's. Eaton Detroit Spring is also very good and can customize the springs to whatever you want. The stock springs were made for hauling and will give you a harsher ride than is needed if you are building a fun truck. Posie's or Eaton Detroit you cannot go wrong.
I assume that you are talking about the parabolic spring kit, I installed them a year ago and it got it way down in the back like i wanted but I ended up installing a small set of air bags because it bottomed out on the frame all the time when carrying anything in the bed and I did not want to notch the frame and then do something for diff to floor of bed clearance.
Received 1,384 Likes
on
I used rear springs from a 1975 F150 in my 53 M100 resto mod with a 9'' rear axle, took a few leaves out for a much smoother ride which I'm very happy with. After the front coils cut down on the 80 Merc car front clip the front sits a bit lower that the rear, back to the planning board. Running boards are on since this picture was taken.
Scott9345
05-01-2005 07:25 PM
