Rear Leaf Spring Options for 54
Old May 1, 2024 | 09:17 PM
StangmanRR05's Avatar
StangmanRR05
2nd Gear
Im looking to replace my rear leafs with stock replacements. Looking for best priced options and where to buy. Will replace rear end with an 8.8. Any advice or recommendations?
Old May 2, 2024 | 07:10 AM
avf100's Avatar
avf100
I used Posies springs on my 55.
TCI sells a leaf spring kit that is a nice set up.
Posie springs with hangers & shackles that i purchased from Mid-fifty.
Old May 2, 2024 | 09:48 AM
ron2565's Avatar
ron2565
I went with Posies super slide for my 54. I got them from Speedway. Simple install.
Old May 2, 2024 | 05:20 PM
bhenders's Avatar
bhenders
People always speak well of Posie's. Eaton Detroit Spring is also very good and can customize the springs to whatever you want. The stock springs were made for hauling and will give you a harsher ride than is needed if you are building a fun truck. Posie's or Eaton Detroit you cannot go wrong.
Old May 3, 2024 | 05:53 AM
Grey County Hermit's Avatar
Grey County Hermit
Do you have stock springs on the front? I have the TCI rear kit and it drops the rear end height a fair bit.
Old May 6, 2024 | 03:51 PM
StangmanRR05
2nd Gear
are those traction bars too?
Old May 6, 2024 | 05:24 PM
lshort's Avatar
lshort
I assume that you are talking about the parabolic spring kit, I installed them a year ago and it got it way down in the back like i wanted but I ended up installing a small set of air bags because it bottomed out on the frame all the time when carrying anything in the bed and I did not want to notch the frame and then do something for diff to floor of bed clearance.
Old May 6, 2024 | 06:41 PM
Fomoko1's Avatar
Fomoko1
I used rear springs from a 1975 F150 in my 53 M100 resto mod with a 9'' rear axle, took a few leaves out for a much smoother ride which I'm very happy with. After the front coils cut down on the 80 Merc car front clip the front sits a bit lower that the rear, back to the planning board. Running boards are on since this picture was taken.
Old May 6, 2024 | 07:58 PM
avf100's Avatar
avf100
I assume your question is for me...no it's a sway bar.
Mike1
May 11, 2021 01:52 PM
PA74F250
Sep 26, 2012 03:57 PM
fat fendered
Jan 12, 2011 08:55 PM
High Intentions
Aug 30, 2010 04:44 AM
Scott9345
May 1, 2005 07:25 PM
