.3 micron CCV filter
This one is 10CFM for 400HP motors….there are different sizes avail. a .03 micron CCV filter sounds great. Since most of the cans and traps don’t do any filtering…should clean up soot nicely
not sure how long it would last since it’s probally. It serviceable and will probably be a throw away item once it gets filled. there are also different size fitting connections.
https://www.jmesales.com/parker-raco...lter-assembly/
Oh woe they sell a replacement element. probably use a back pressure gauge to tell if it is full.
https://www.jmesales.com/parker-raco...er-assemblies/
sounds like a good place to put a drain petcock valve.
Hose kits
Not cheap but if you want true CCV soot filtering and fluid separation I think this is the ticket.
About the size of a coffee can
the spec sheet pdf
https://www.parker.com/content/dam/Parker-com/Literature/Racor/Racor-Engine-Air-Filtration_-_CCV4500-Crankcase-Ventilation-Filter_-_7761.pdf
Two densities of filter media
Hose kits
the spec sheet pdf
I just ordered the RACCV450008R model.
the inlet and output fittings would be the same size as the connector to our CCV inlet to the returns tube.
my stock CCV filter element is already removed so all I have is the CCV case which is now wide open. So all I have to do is disconnect t my current CCV hose at the pre-turbo connection , put in a male to make adapter, run some hose to this filter, run hose back to the pre-turbo connector.
the hose on Amazon for oil grade 1 1/4 tubing is 50 bucks for 25 ft, so I’ll have extra. The two 1 3/16 -12 SAE fittings are less than ten bucks for a pair.
I went with the RACCV450008R unit becuase the fitting size was a good match, although it’s rated for 400HP, I think it will be fine. Big price jump to go to the next model rated for 600HP and the fittings are larger which will require reducers.
There are three sizes of these…some where in the area of these specs
400hp /10CFM
600hp/20CFM
800hp/40CFM
I ordered one because I need a drain able can with a filter.
i think the 400hp unit will be fine…worst case it will fill up quicker than the projected 20k miles.
the delivery is on back order.
when i get it installed, ill run periodic back pressure test and liquid capture updates.
400hp /10CFM
600hp/20CFM
800hp/40CFM
Hose kits
the spec sheet pdf
Hose kits
the spec sheet pdf
AND I've been corrected... seeing the size of the diesel engine that the CCV4500 is mounted to on the product spec brochure, I'm sure it would work just fine on our 6.7s...
