Excursion tow hitch Options
...or just ask the many members who have them. Depends on how serious you are about towing, and how safely.
Apparently @ExxWhy is famous?
Rear collision avoidance system -> https://www.torklift.com/rv/superhit...al#accessories LOLZ
The Curt seems to be a good replacement that pretty closely matches the factory hitch. The SuperHitch from TorkLift is a very stout piece of hardware, I love mine but I needed something a little stronger than the factory unit, our TT's tongue weight is over 1800lbs, but its obviously overkill for a rig that doesn't see as much weight.
The lowest tow rating for any year EX was 10K, and that was later increased to 12K (or 12.5 I don't recall) by the use of slightly larger hitch to frame bolts, the hitch was exactly the same except for having the holes for those bolts matched to size.
If you are going to DIY the hitch replacement have a plan in place for dealing with the round headed bolts, they can be a real pain to deal with. I found that dropping the tank, which is a fairly easy job, to give the best hitch access. The factory used blue thread locker on the bolts, so a bit of heat from a propane torch will make spinning them out much easier, just watch that flame if you leave the tank in place...........
Yes, it's a serious piece. The Curt wasn't even available when I got mine. Torklift makes some great products, really liking their steps too.
Shank XL 30K M9001 (top right of page):
Seems like having double beams (or whatever they call them) inserted into the receiver would seriously strengthen the whole deal.
I know as rust free as my Ex is, it's still got some 'egging' starting in the hitch pin hole area, so I'm glad to see these are reinforced.
Sorry for the temporary hijack OP!
Many times the hitch pin hole egging can be caused by the bent end of the hitch pin working into the hole then hogging that hole out a little as you move down the road. By placing a small hose clamp right on the pin just before the bend that can be avoided, I use a factory style squeeze clamp on mine and have not seen any egging of the hole on either the factory hitch or the SuperHitch in over 47K heavy towing miles.
Pulling a 10k enclosed race car trailer, soon to be pulling a 32' travel trailer occasionally.
I am luvvin' that Torklift receiver. Changing to a Class IV has been on my to-do; this just went on my wishlist.
Do I need this: absolutely not.
Do I get a kick in the pants when someone says “Wow, now that’s stout!”: absolutely.
