Excursion tow hitch Options
Old Apr 15, 2021 | 01:44 PM
Forresth's Avatar
Forresth
Is the Curt 14011 the only option for an excursion hits?
Do F250 hitches work as well?
any other options?
Old Apr 15, 2021 | 02:11 PM
thor363's Avatar
thor363
https://www.torklift.com/blog/entry/...s-all-you-need
...or just ask the many members who have them. Depends on how serious you are about towing, and how safely.
Apparently @ExxWhy is famous?
Old Apr 15, 2021 | 02:45 PM
Forresth's Avatar
Forresth
not quite that serious, especially for a truck rated for less than 10k
Old Apr 15, 2021 | 02:52 PM
thor363's Avatar
thor363
If you run a drop hitch shank, you can accumulate hot-rod Honda's on it, and not skip a beat.
Rear collision avoidance system -> https://www.torklift.com/rv/superhit...al#accessories LOLZ
Old Apr 15, 2021 | 04:09 PM
EXSwap's Avatar
EXSwap
The Curt will do you just fine if you don't want to go with the super hitch. And no, any other hitch will not work as the X rear frame is exclusive to it.
Old Apr 15, 2021 | 05:33 PM
WE3ZS's Avatar
WE3ZS
Correct, the pickup truck hitches will not work on an EX as the rear frame sections are different, the truck hitch will mount but the receiver will be pointed down about 30 degrees.
The Curt seems to be a good replacement that pretty closely matches the factory hitch. The SuperHitch from TorkLift is a very stout piece of hardware, I love mine but I needed something a little stronger than the factory unit, our TT's tongue weight is over 1800lbs, but its obviously overkill for a rig that doesn't see as much weight.
The lowest tow rating for any year EX was 10K, and that was later increased to 12K (or 12.5 I don't recall) by the use of slightly larger hitch to frame bolts, the hitch was exactly the same except for having the holes for those bolts matched to size.
If you are going to DIY the hitch replacement have a plan in place for dealing with the round headed bolts, they can be a real pain to deal with. I found that dropping the tank, which is a fairly easy job, to give the best hitch access. The factory used blue thread locker on the bolts, so a bit of heat from a propane torch will make spinning them out much easier, just watch that flame if you leave the tank in place...........
Old Apr 15, 2021 | 07:49 PM
ExxWhy's Avatar
ExxWhy
Ha, I had no idea! Yes, it's a serious piece. The Curt wasn't even available when I got mine. Torklift makes some great products, really liking their steps too.
Old Apr 15, 2021 | 07:52 PM
thor363's Avatar
thor363
Don't you at least get royalties?
Old Apr 15, 2021 | 08:00 PM
thor363's Avatar
thor363
Tom, did you get one of these for yours?
Shank XL 30K M9001 (top right of page):
Seems like having double beams (or whatever they call them) inserted into the receiver would seriously strengthen the whole deal.
I know as rust free as my Ex is, it's still got some 'egging' starting in the hitch pin hole area, so I'm glad to see these are reinforced.
Sorry for the temporary hijack OP!
Old Apr 15, 2021 | 08:04 PM
ExxWhy's Avatar
ExxWhy
There was a t shirt and a koozie involved. It was all after the review she asked if she could quote me on that, honest it's a nice piece.
Old Apr 15, 2021 | 09:33 PM
WE3ZS's Avatar
WE3ZS
No, on the double beam insert, I use a Hensley Arrow which uses a unique (but very similar to the Pro-Pride) stinger drawbar, so that double deal would not be a usable option for me.
Many times the hitch pin hole egging can be caused by the bent end of the hitch pin working into the hole then hogging that hole out a little as you move down the road. By placing a small hose clamp right on the pin just before the bend that can be avoided, I use a factory style squeeze clamp on mine and have not seen any egging of the hole on either the factory hitch or the SuperHitch in over 47K heavy towing miles.
Old Apr 16, 2021 | 08:05 AM
thor363's Avatar
thor363
Thee egging on mine is minor, but when I get the new hitch will definitely remember this advice. If I can rep you (again) I will...for what it's worth! Still looking at the 334RLOK
Old Apr 16, 2021 | 10:20 AM
GregA's Avatar
GregA
I've been using a 5/8" Grade 8 bolt with washers and nyloc on mine. The bolt snugs things up nice, and stops the rattling and egging. Plus, you'll need to be carrying a 15/16" wrench and socket to steal the trailer...
Pulling a 10k enclosed race car trailer, soon to be pulling a 32' travel trailer occasionally.
I am luvvin' that Torklift receiver. Changing to a Class IV has been on my to-do; this just went on my wishlist.
Old Apr 16, 2021 | 10:33 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Torklift has this attachment that fit the dual receivers. I got a couple of locks keyed the same for convenience.
Do I need this: absolutely not.
Do I get a kick in the pants when someone says “Wow, now that’s stout!”: absolutely.
Old Apr 16, 2021 | 11:11 AM
carbon coupe's Avatar
carbon coupe
DOUBLE DONG OVERKILL....does this mean you can tow 2 trailers at once?
