BWST's F350 maintenance/upgrade thread
Details of this rig are in my signature. It has a few issues, but runs and drives fairly well. It will not be my daily driver now, so I can take my time working on it, which is nice.
2001 F350 Lariat 7.3L 4x4 CCLB SRW 4R100
Purchased for $15K+tax May 5, 2020 with 269,275 miles on the clock
Build Date: Aug 2000
May 25, 2020.....269,393 miles
-R&R Front Axle shafts, replace seals, right U-joint, needle bearing, stub shaft
Axle, outer stub, Spicer 2002692, Amazon, $55.69
Bearing, needle, Timken B2110, Amazon, $10.59
O-ring, vacuum hub, Ford FB1Z-4A322-AA, Amazon 2@$6.30ea
Seal, outer axle shaft, National 710493, Amazon 2@$21.30ea
Seal, axle shaft, National 710413, Amazon 2@$3.26ea
Washer, axle hub thrust, Ford F81Z4228BA, Riffraff 2@3.68ea
Dipstick, transmission, Ford F81Z7A020BA, Riffraff $19.32
June 5, 2020.....269,700 miles
Information starts at post #117
-R&R ICP Sensor
3/8" tubing, aluminum, fuel line, 6"
Filter, fuel, inline, 5/16", Wix 33972, Amazon $12.20
Hose, fuel injection, 5/16", SAE 30R9, 18", Dayco 80079, Amazon $11.00
Clamp, fuel injection, 5/16", 4 ea
Filter, fuel, Motorcraft F81Z9N184AA, Riffraff $21.53
July 5, 2020.....269,790 miles
Information starts at post #119
-R&R GPR
August 2, 2020.....270,100 miles
Information starts at post #186
-R&R Belt
September 14, 2020.....270,250 miles
Information starts at post #226
-R&R HPOP Lines
HPOP JIC LINE, Pass side head, 99-03, Riffraff RDP-HPOP-PASS $88.41
December 15, 2020.....270,800 miles
Information starts at post #253
-R&R Sound system
Camera, rear, ATOTO AC-HD03, Amazon $49.13
Harness, Metra 70-1771, Amazon $7.21
Kit, solder sleeve, Kuject WT001, Amazon $8.99
Gauge, fuel pressure, 0 to 100psi, Isspro EV2, R17044, Riffraff $149.88
Pod, Triple gauge, Autometer 18017, Amazon $67.04
Kit, Snubber, 99-03, Riffraff R78828, Riffraff $9.99
Plug, gauge hole, 2", Riffraff R7614, Riffraff $4.96
Mount, Hydra, HYDRA-MNT, Riffraff $25.67
Information starts at post #351
-R&R Door Weatherstrip
Clamp, 3.5", Nickson 517312, Advance Auto $5.49 x 2
Plug Mount, 125V 15A, 16" pigtail, Noco GCP1, Amazon $23.41
Caliper, driver rear, limited lifetime, Duralast 18-B4753, Autozone $63.19
Information starts at post #477
-Install Block Heater Plug Mount
Switch, SPST, red LED, V1D1-GCCB, RockerSwitchPros $16.50
Switch, DPST, red LED, VAD1-GCCB, RockerSwitchPros $28.00
Actuator, custom Exhaust Brake, RockerSwitchPros $12.00
Actuator, custom Glowplug Enable, RockerSwitchPros $12.00
Fuseholder, Inline, mini, Littelfuse FHM2BP, O'reilly Auto Parts $3.99
Housing, thermostat, billet, black, Riffraff RDPTSTATH-BLK, Riffraff $46.22
Information starts at post #625
-R&R Transmission Cooler
Adapter, 1/2"ID to 3/8" ID, barbed, brass, Joywayus JWBTYZ08-12, Amazon $5.99 x 2
Hose, Oil Cooler, 1/2" ID, 150psi, 12ft, Hayden #112, Amazon $16.51
October 2, 2021.....272,900 miles
Information starts at post #627
-Rebuild Turbo
Up pipes, bellowed, w/ collector, eBay (first.racing) $67.99
Exhaust wrap, 2" x 50', ARTR-2-50, Amazon $17.99
Compressor wheel, 7/7, billet, FTE, no charge
EBPV rebuild kit, Garrett 729519-0003, Riffraff $97.52
Plenum Inserts w/ 4 clamps, Riffraff RDPPRI, Riffraff $54.70
Pads, Rear, Yellowstuff, EBC DP41603R, FTE $N/C
Rotors, Front, Motorcraft BRRF-103, $90.93 x 2
Rotor, LR, ACDelco 18A934A, Amazon $36.53
Core credit, HPOP, CNC Fabrication, -$150.00
IPR reseal kit, Motorcraft 14-007, Dieselorings.com, $13.76
May 6, 2022.....275,600 miles
Information starts at post #778
-R&R Coolant
Gasket, reusable, Lubelocker LLR-F105, Amazon $22.95
Cover, finned differential, Dorman 697-725, Amazon $58.39
Cap Screw, 5/16-18, 1-1/4", SS, qty 25, Amazon $16.98
Washer, 5/16, split, SS, qty 15, The Hillman Group 2238, Amazon $3.98
Gasket, reusable, Lubelocker LLR-D060, Amazon $21.95
September 18, 2022.....278,000 miles
Information starts at post #824
-R&R Transmission Cooler Bypass
Hose, Hydroboost to steering box, Gates 352790, Amazon $5.68
November 21, 2022.....279,000 miles
Information starts at post #859
-R&R Torque Converter
March 18, 2023....281,000 miles
Information starts at post #872
-R&R Mud Flaps
June 1, 2023....282,000 miles
Information starts at post #878
-R&R Water Pump Intake Elbow
September 22, 2023....283,500 miles
Information starts at post #931
-R&R Front Shocks
Shock, rear, 4600 Series, Bilstein 33185347, Amazon $77.03 x 2
December 15, 2023....285,000 miles
Information starts at post #962
-R&R Radio
Harness, radio, Ford 98 and up, Metra 70-1771, Amazon $5.99
Adapter kit, American International FM-K550, Amazon $13.55
Holder,cell phone,dash/windshield mt, iOttie 5 2nd gen, Amazon $18.95
Cord magnets, Sinjimoru MCH_BASC, Amazon $11.19
April 26, 2024....287,000 miles
Information starts at post #967
-R&R Starter
May 12, 2024....287,900 miles
Information starts at post #985
-R&R Batteries
Quarterhorse datalogger/emulator brd, PHP $350.00
July 18, 2024....289,500 miles
Information starts at post #1105
-R&R Turbo
Sensor, pressure, 0-100PSI, ISSPRO R89150 $60.59
Harness, boost, ISSPRO R72014 $29.67
Connector, IDC, ISSPRO R82012, $1.89
August 3, 2024....290,100 miles
Information starts at post #1162
-R&R Injectors
September 2024....291,500 miles
Information starts at post #1283
-R&R Tailgate handle
Information starts at post #1357
-R&R Power Steering hose
Information starts at post #1381
-R&R Upper alternator
Information starts at post #1498
-R&R rear differential
Ron's Machining Service $990.00
Spacer, solid, 10.5 pinion, RMS SK CSF9, Ron's Machining Service $28.00
Truetrac 10.5 differential, Eaton, Riffraff $829.99
Oil, 75W140, Amazon $10.75 x 3.5
Threadlocker, red, high strength, Loctite 263, Amazon $9.75
Threadlocker, blue, med strength, Permatex 24010, Amazon $10.75
Sleave retainer, green, Permatex 64000, Amazon $10.75
Seal, o-ring, drive axle shaft, pair, Napa 926163 $12.79
Seal, rear hub, Napa 29425 $50.29 x 2
-R&R CAC boot
August 2025....296,700 miles
Information starts at post #1636
-R&R Transmission
Bearing, center support, S36224A, Transmission Bench $16.65
Radiator, NRC NR2171C, Napa, $301.99
Assembly lube, tub, Lubegard, Amazon $17.25
Parts washing fluid, mineral spirits, gal,Kleen, Walmart $18.00
ATF, MerconV, qt, Napa $7.99 x 20
Information starts at post #1896
-R&R Front Differential
Oil, 80W-90, Castrol, qt, $8.99 x 4
Here is the snapped off vacuum port.
I capped it off with a brass plug.
What do you think it will take to free up the shaft from the hub? I can probably remove the hub and shaft assembly as a unit and work on this in the shop. Hoping the shaft is not too badly damaged from this. Assuming I need to separate the shaft from the hub assembly and clean it up, then replace the small bearing it rides on inside the hub assembly, if possible.
Thanks for the welcome back, Sous!
This side of the front axle is a beast. I never pulled axle shafts before. They are substantial.
Predictably, the needle bearings are shot. The shaft is pretty scored up as well.
So I need a stub shaft, a u-joint, some seals, and a needle bearing. Kinda fun learning about all this. Might pull the other side too and see where things are at. I think the bearings are ok there, just some dust seal wear, though the needle bearings might be low on lubrication. Good time to check the brakes on that side as well. It pulls a bit to the left.
Edit: adding reference to SuperdutyPSD.com's ball joint R&R article - has excellent instructions for removing the unit bearings: https://www.superdutypsd.com/ball_joint_article.php
Do you have or have access to the large vacuum seal tool? If not I have the Lisle tool you can borrow.
The Timken Needle bearings are pretty inexpensive too. https://smile.amazon.com/dp/B000BZ54...v_ov_lig_dp_it
As you can see, the stock air box is there. I suspect it has not been sealing well at times. No blowby at the oil fill, but the stock garrett turbo has evidence of dusting:
Interior view. The driver seat leather has been replaced. Passenger side is pretty worn, but not ripped.
Transmission dipstick tube was broken off and lodged down on the passenger framerail. There's a plug sitting in the remaining stub. Not a good sign, but it drives/shifts well (so far).
The downpipe appears to be the stock diameter (3"). 3.5" stock exhaust starts after the pipe transitions to horizontal.
Good [link] to what @Baatzy worked through. I think my issues are likely wiring/connector related.
I'm referencing the ESOF troubleshooting guides for a 2000 truck from our tech folder as well - very helpful
What I've checked so far:
- all fuses in the central junction box and under hood junction box. removed and reinserted as well.
- no power to shift motor when I operate the selector switch. no clicking from the under hood shift relays either.
- shift motor - works when I apply 12V. Operates one direction or the other depending on the polarity I apply.
- selector switch - forscan shows GEM is seeing it switch between 2WD, 4Hi, 4Lo. Measured voltage on dark blue wire at switch in each position: 5.6V, 2.5V, 0.9V
- dash indicators - just have 4x4, not Low Range. Checked by removing shift encoder from shift motor assembly and moving it manually. Might have a bad light.
-shift relays - bench tested - appear to work with power applied, continuity verified between appropriate blades of the relay energized and de-energized.
-power at shift relay mounts, location 86 and 87, both relays. Grounds appear good at 87a, both relays.
-pulled fuse block/GEM and it appears to be in good shape in terms of no water damage. Solder joints look good both sides of PCA. All connector pins clean.
I can apply power to the shift motor by jumper at one relay mount, 30 to 87, leaving the other relay to provide a ground path. Shift motor runs when I do that.
Connector to the shift encoder will not latch - easy to slide off. When sliding it on, it does not click, and I can't slide the red clip in. I think the nub on the encoder side is worn, Not sure yet best way to fix this.
I appear to have an open wire between low-to-high shift relay coil pin 85 and GEM C240c pin 10, ckt 782. I have continuity between the other shift relay coil pin 85 and GEM C240c pin 11, ckt 781.
Note in the illustration, the view of the relay mount is from underneath (what they call "harness side").
Here's the shift motor encoder connector. Interesting how the red slide works. I'm trying to understand it, but it appears to be locked open when not inserted in a connector. I think the nub in the mating connector has to push the tip of the red slide such that the whole red clip can slide home. I played with the connector on the MAP sensor which operates similarly. Still hard to see what's going on there.
https://www.superdutydiesel.com/thre...g-p1820.24445/
If cleaning and reseating the fender connectors does not solve the problem, I might run a new wire. There are some extra wires labeled "customer access circuits" that pass through the firewall. I could use one of those.
Several weatherproof joints to make though to get that BR/WH wire connected. Certainly better if i could find the break.
- Low-To-High Relay to C1044M
- C1044F to C1051F
- C1051M to C240c at the GEM pin 10.
