radiator repair with super glue and baking soda
Old 04-21-2019, 01:24 AM
paker's Avatar
paker
paker is offline
I cracked the radiator (the plastic side) of a non-F150 Ford (Edge to be exact) while removing the radiator fan. I read about plastic weld with a high wattage soldering iron, but the location of the crack does not allow access. I also read about superglue and baking soda trick. Does it really work? According to internet, superglue and baking soda react chemically, and generate high heat, locally melting and bonding plastic. Does anyone have a firsthand or second hand experience with this trick?
Old 04-21-2019, 07:27 AM
rmccbride's Avatar
rmccbride
rmccbride is offline
I use super glue for fixing lots of stuff, and with baking soda when needing to build up the area. Yes it does get hot but don’t think it’s going to melt plastic hot.. I would go ahead and give it a try.. Superglue is also great for fixing tires on garden equipment.
Old 04-21-2019, 09:59 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is online now
It will probably work until the system builds up pressure. You could ride around with the cap loose until you can fix it right.
Old 04-26-2019, 02:03 PM
paker's Avatar
paker
paker is offline
Thank you for your advice. I replaced the radiator.
Old 04-26-2019, 03:46 PM
rmccbride's Avatar
rmccbride
Without trying to repair it?
Old 04-27-2019, 09:42 AM
alloro's Avatar
alloro
alloro is offline
Received 4,198 Likes on 2,433 Posts
If you think a new radiator is expensive, try fixing an overheated engine with warped heads.
Old 04-27-2019, 11:16 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
The plastic tank radiators are not worth attempting to repair.
Nodrama
07-09-2017 11:32 PM
F350moneypit
08-08-2015 09:51 AM
Whiplaunch
08-19-2014 11:54 AM
primer85f150
07-03-2011 08:27 AM
Dads79
03-07-2007 01:28 PM
Quick Reply: radiator repair with super glue and baking soda
