What radiator is everyone using?
Old Jul 2, 2017 | 03:08 PM
Nodrama's Avatar
Nodrama
1983 F250 HD 4x4 460ci 4-speed with super cooling option per the Marti Report.
The original radiator is done after 99k miles. I want to replace it as the cost of a recore is probably to expensive. Is there anyone building a good radiator that is a drop in replacement? I see lots of different brands and all kinds of price variations. I want a good one that will last another 100k miles.
Plastic tank and aluminum core?
All aluminum construction?
Thoughts?
Old Jul 2, 2017 | 03:27 PM
Resto's Avatar
Resto
Using the 3 row stocker but check out LMC Truck, Bronco Graveyard & Parts Geek. Use your old one for dimensions! I would stay away from ones with plastic end tanks...all aluminum construction over plastic any day.
Old Jul 2, 2017 | 04:29 PM
FuzzFace2's Avatar
FuzzFace2
I am also not a fan of the plastic/alum ones so if I could not go with a copper/brass one then the all alum.
Have you checked with a local radiator shop to see what they can do for you?
Dave ----
Old Jul 2, 2017 | 04:45 PM
kr98664's Avatar
kr98664
My recent experience here, on an '84 351W:
https://www.ford-trucks.com/forums/1...lant-leak.html
Here's where I got my radiator. I went with the heaviest duty option, the three row aluminum version. They listed the same #220452 for your truck, too:
https://www.radiatorexpress.com/part...tepCompleted=5
Old Jul 2, 2017 | 05:02 PM
Nodrama's Avatar
Nodrama
thank you ! I will check them out as well.
Old Jul 2, 2017 | 05:38 PM
Nodrama's Avatar
Nodrama
this one from Radiator express claims to be copper/brass.
https://www.radiatorexpress.com/prod...d=1123681#tabs
I like this one or the aluminum version offered as well. Thanks Karl for the link.
Old Jul 9, 2017 | 11:32 PM
gravelstne's Avatar
gravelstne
Try and get a 3 row aluminum with plastic tanks. I run my power steering cooler through the trans cooler for quieter PS pump since its a 4 speed
86-IDI
Feb 23, 2019 05:52 PM
SgtOtaku
May 9, 2017 10:21 PM
F350moneypit
Aug 8, 2015 09:51 AM
JoeVB
Dec 24, 2005 07:28 PM
maticuno
1997 - 2003 F150
Dec 11, 2005 07:07 PM
