Pcv setup
Pcv setup
Hello, so I have searched all previous threads on this topic and could not find the specific answer to my question, so here it goes
My 64 F250 has it's Y block out getting rebuilt. After smoking myself out at a light, I've decided to ditch the draft tube. I bought a PCV conversion for a 57 Thunderbird, this kit eliminates the draft tube with a grommet in the valley cover, pcv valve up to a hose and into a supplied carburetor base plate.
my question is do I leave the vented oil fill cap, or do I have to switch to the non vented with a hose to my new air cleaner?
Thanks in advance!
Thanks in advance!
Upper pic: 1961/63 is the same. The 6A665 adapter replaced the road draft tube.
I know, it is a kit I purchased through Hills Automotive in Ohio. Converts 57 and later y block (4 barrels) to pcv.
so the pictures are a help but leave out the oil fill cap, still not too sure about vented or non vented.
I understand that in order to evacuate Crankcase pressure, fresh air needs to come in, but is the vented cap enough or does it need a feed line from the air cleaner?
Thanks
Thanks
My f350 has a 62 engine in it. Before rebuilding it the engine had a pvc system that used the front vacuum port in front of the carb. I installed a valley cover that was modified to have the pcv valve directly sticking into the valley from where the road tube had been. My hose still goes around to the intake in front of the carb. From other posts I've read I would keep the vented fill cap because the valley cover has a piece that goes across inside that blocks/limits the draw on the front half of the engine. So the pcv is basically drawing against the back half of the engine.
I actually have the 6A664 PCV in my 64 F250. It runs with the vented cap on oil filler tube, one of the posters is correct, keeping a clean fill tube vent is good practice. Most of us that own these old machines are (I think) pretty meticulous with maintenance anyway, but it was a good tip.
hooler1
04-16-2011 11:00 PM
phurst
01-06-2011 06:07 PM
deyomatic
12-17-2008 07:52 PM
