Bypass thermactor air pump ?
Ok....I have a 1991 f150 XLR lariat 5.0 with aod trans. The thermactor air pump froze up .. so I got another shorter belt to bypass it..also bypass a/c compressor( it dont work also) so I put the belt on the essentials. ...almost right away it started leaking power steering fluid and it's not charging....had auto zone test alternator and it's fine.....did I do something wrong....are things spinning faster since I bypassed the 2 pulleys....the belts tight so now I'm stuck....help
What he said. In addition a little bit of Googling most likely would have gotten you part numbers for the air pump and a/c bypass pulleys.
gman97005
11-21-2013 03:11 PM
DJdemon6696
09-05-2009 10:29 PM
BlueTorpedo85
01-29-2005 05:08 PM
