If it dosn't have the air pump there should be a bracket with an idler pulley on it in its place , then it will use the stock belt . I could give you the number of my belt but i have underdrive pulleys so it wont be the same . Mine is a 95 so i don't know what year yours is & if they are the same ?? ...Lew
Ok mine is a 950K6 but i use a FR idler where the air pump was . You can just put the old belt on & see how much shorter it has to be or just measure it with some string . You might have to try a few belts , then take back the ones you don't need thats what i did ... Lew
