Bypass thermactor air pump ?
Old Dec 13, 2018 | 12:19 PM
Tricci's Avatar
Tricci
Ok....I have a 1991 f150 XLR lariat 5.0 with aod trans. The thermactor air pump froze up .. so I got another shorter belt to bypass it..also bypass a/c compressor( it dont work also) so I put the belt on the essentials. ...almost right away it started leaking power steering fluid and it's not charging....had auto zone test alternator and it's fine.....did I do something wrong....are things spinning faster since I bypassed the 2 pulleys....the belts tight so now I'm stuck....help
Old Dec 13, 2018 | 02:00 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
There are bypass pulley kits for the air pump and a/c compressor, that would have taken care of it so you could reuse the same belt.
Old Dec 14, 2018 | 10:31 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What he said. In addition a little bit of Googling most likely would have gotten you part numbers for the air pump and a/c bypass pulleys.
gman97005
Nov 21, 2013 03:11 PM
broketruckjohn
Aug 31, 2013 01:02 PM
DJdemon6696
Sep 5, 2009 10:29 PM
MustangGT221
Nov 24, 2008 05:51 AM
BlueTorpedo85
Jan 29, 2005 05:08 PM
