Need help with dual wheel removal
Old 10-16-2018, 08:27 PM
Jlwhitt77's Avatar
Jlwhitt77
Jlwhitt77 is offline
I apparently am not smart enough to remove the dual wheels from my 51 F5. After you remove the outer dual, do you remove the stud to get the inner off? It looks like it should slide off over the studs .
Old 10-16-2018, 08:44 PM
pikeman's Avatar
pikeman
pikeman is offline
Nope,those are threaded on, and hold the inner wheel in place.
Old 10-16-2018, 08:49 PM
Jafo56's Avatar
Jafo56
Jafo56 is offline
My f-4 came with the lug wrench...which included the square piece that goes over the stud........ don't forget reverse threads on left side
Old 10-16-2018, 09:09 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,640 Likes on 1,470 Posts
JLWhitt, welcome to FTE the best Ford truck Forum on the world wide web!
Show us pictures of your truck and tell us some of it's history.
Old 10-16-2018, 09:26 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Welcome Jlwhitt77.
There are inner nuts and outer nuts. You have removed the outer nuts to get the outer wheel off, now you need to remove the inner nuts to remove the inner wheel. Inspect the wheel stud holes for wear to be sure the inner nut isn't contacting the hub. The inner nuts are stamped L or R on their face to indicate the thread type.
Also, the tightening torque on the lug nuts is 450 - 500 ft. lbs.
It also looks suspect that you have the widow maker wheels.
Old 10-17-2018, 02:46 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
These below pictures might help understand the Budd style “double cap nut”, or DCN, mounting system. The wheel pictured, and others like it, have the “widow maker” “ Firestone RH-5°“ style outer rims. A Google search will yield much info on their safety risks. Below are also pictures of their center line rim joint. Stu
Widow maker joint.
Old 10-17-2018, 04:01 AM
Jlwhitt77's Avatar
Jlwhitt77
Originally Posted by Mixer man
Welcome Jlwhitt77.
thanks for the help. I do have the Firestone wheels and am well aware of the danger .
Old 10-17-2018, 04:05 AM
Jlwhitt77's Avatar
Jlwhitt77
Thanks for the help fellas. I feel like a moron. I tried everything to get that wheel off. I guess it would help if I removed all the fasteners. I need in there to repair the wheel cylinder. I am close to having this truck driving again.
Mikenelsonscrappy
1947 and Older Ford Trucks
06-07-2019 12:50 PM
460f250
11-06-2005 09:18 PM
qarad4
1997 - 2003 F150
07-05-2004 09:16 PM
bigtoy
08-27-2000 11:18 AM
Quick Reply: Need help with dual wheel removal
