1946 jail bar truck
1946 jail bar truck
Hi new to the site need some info about my 1946 truck
im trying to remove rear dual wheels (5 lug large hole ) have removed lug nuts and outer wheel, inner wheel is stuck fast I can’t see any form of fixing I’ve tried all sorts but no good any help would be helpful thanks Mike
Did you remove the inner lug nuts?
Usually, using a large hammer and a short length of two by four positioned to the inside of the wheel will do it. Or you might try re-installing some inner lug nuts, but don't tighten them, leave them about an eighth inch from contacting the wheel. Lower the truck until the tires are setting back on the ground with the full weight of the truck on them. Push the truck side to side until the wheel loosens from the hub.
1946 jail bar truck
Hey once the lug nut is removed then the outer wheel all that’s left is the inner wheel sitting snuggle on the half shaft hub and the lugs it does feel like something else is holding them on I’ve even had Porto power between wheel and brake drum to which no movement at all
raytasch
10-02-2012 09:36 PM
dark_flame221
05-04-2010 09:23 AM
