LED eagle eye lights in dash panel - who did this mod?
Months ago I read a thread on here where one of our members used a set of these in their dash. I can't find the thread anymore so I'm asking for everyone's help. Here is an image of what was used.
Twister, I've used them for indicator lights. I wouldn't think it would be too difficult to put them in the instrument cluster. Disassemble the cluster and open bayonet/twist in holes to 1/2". I think it'd be wise to use a rubber washer between the nut and the printed circuit. Then run each LED's hot wire directly to the panel light wire coming off the headlight switch. And run all the ground wires to a common ground screw on the dash support frame. I would use quick disconnects for the ground and hot wires so you can easily remove the cluster in the future.
